Need help installing a Autometer tac
Old Jan 8, 2003 | 06:14 PM
bennyj's Avatar
Default Need help installing a Autometer tac
Just got an autometer tach with shift light just wondering how to install it on a 98 Civic Dx
Old Jan 8, 2003 | 07:32 PM
TREVER's Avatar
Default Re: Need help installing a Autometer tac (bennyj)
here is what you do first, get out the INSTRUCTION MANUAL and read it.
Old Jan 8, 2003 | 07:34 PM
acydphryck's Avatar
Default Re: Need help installing a Autometer tac (TREVER)
damn TREVER!!! you n00b slayer!!! u shouldn't **** on all the n00b's like that...might give ht a bad rep...
Old Jan 8, 2003 | 07:44 PM
TREVER's Avatar
Default Re: Need help installing a Autometer tac (acydphryck)
sometimes you need to help people help themselves
Old Jan 8, 2003 | 07:52 PM
tominos's Avatar
red to power, black to ground, signal wire to blue wire on distributor, or matching wire on ecu or back of dash. u gotta cut some wires on the back of the tach to read correctly for a 4 cyl. i think. good luck
Old Jan 9, 2003 | 12:31 AM
SuperSH's Avatar
Default Re: Need help installing a Autometer tac (tominos)
You shoulden't need to cut any wires to get the correct cyl. number. You just have to read the instructions that came with the tac to figure out how to change how pulse signal is read. As far as the wires go
RED=Igniton switched power
BLACK=Good chassis ground or direct battery ground.
WHITE= Headlight switched power
BLUE?= Tac signal off ecu/distributer (Usually blue wire)
Old Jan 9, 2003 | 12:36 AM
Cnote's Avatar
actually use the blue wire on the driver side strut tower harness, it has a single blue wire that is placed in a black rubber housing. It's usually black taped to the other plug at the strut tower harness.
Old Jan 9, 2003 | 02:36 AM
TEAMGENDAI's Avatar
Default Re: Need help installing a Autometer tac (Cnote)
red = ign
black = ground
white = for running lights
breen = goes to yellow with green stripe on distributer or blue single wire on driver side it'll have a little black cover on it it will be all by itself
[Modified by TEAMGENDAI, 11:36 AM 1/9/2003]
Mr.vang
Feb 14, 2008 04:33 PM
VTECLuDe96
May 14, 2003 08:05 AM
D1ANCER
Apr 2, 2002 11:05 PM
nkSi
Sep 30, 2001 09:47 AM
