Need Help!!!! IAC or TPS problem
Old Feb 21, 2006 | 04:01 PM
DaveSI99's Avatar
Default Need Help!!!! IAC or TPS problem
I have a 99 civic si with a JDM ITR motor. When you turn on the car cold it idles like around 1-1.5K then when it warms up and you step on the gasit goes up to or about 2-2.5k and it just stays like that and it also has a loud whinning sound coming from it. I've tried another IAC valve and still having a problem. When I unplug the IAC it idles normal but I throw a check engine light. Could it be the TPS?? Someone had mention spark plugs, could that cause high idle?? Please give me more things to look for. Thanks in advance for any advice .....
Modified by DaveSI99 at 8:17 PM 2/21/2006
Modified by DaveSI99 at 9:10 PM 2/21/2006
671islander
Aug 29, 2009 04:27 PM
2000turbosi
Mar 23, 2009 01:32 PM
SOHCD16y8
Mar 5, 2006 06:47 PM
jdkornlp
Feb 23, 2006 02:32 PM
