need help..h22a motor!
Old Apr 8, 2004 | 09:40 AM
Juan Q...'s Avatar
Default need help..h22a motor!
I just installed Crower Cams on a 98-99 Accord with 99 H22a swap and when it hits vtec it feels like it has a rev limiter. what could it be? I have done everything and no luck please help. any help will be appreciated.
Old Apr 8, 2004 | 12:32 PM
h22 civic's Avatar
Default Re: need help..h22a motor! (obdjuan)
what ecu you useing?
Old Apr 12, 2004 | 11:08 AM
Juan Q...'s Avatar
Default Re: need help..h22a motor! (h22 civic)
Chipped p28
Old Apr 12, 2004 | 12:27 PM
irev210's Avatar
could you explain the rev limiter issue a little more?
im a bit confused
Old Apr 12, 2004 | 01:58 PM
MrParks's Avatar
you need tunning for sure but first you need to make to put a fuel reg, check the ecu also, i know you need more fuel.
Old Apr 12, 2004 | 08:09 PM
H22CL's Avatar
is the engine shutting down when vtec engages? explain a lil more what happens.
Old Apr 13, 2004 | 12:00 AM
ea_hatch's Avatar
Default Re: need help..h22a motor! (HARTENG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HARTENG &raquo;</TD></TR><TR><TD CLASS="quote">you need tunning for sure but first you need to make to put a fuel reg, check the ecu also, i know you need more fuel.</TD></TR></TABLE>
that sounds like the prob to me
Old Apr 15, 2004 | 06:16 PM
Phillip4288's Avatar
Default Re: need help..h22a motor! (ea_b16hatchie)
Sounds to me like you need a fuel reg man
planomatt
Feb 16, 2005 08:39 AM
VashTheStampede
Aug 25, 2004 01:27 PM
Se-rv-Tak
22
Apr 6, 2004 02:47 PM
gsrcivict
Dec 15, 2002 05:15 PM
