Need help guys. Engine wire harness?
Old Apr 19, 2002 | 08:38 AM
g's integ's Avatar
Default Need help guys. Engine wire harness?
Does the 92-95 Si same as 94-95 GS-R engine wire harness the same?
Old Apr 19, 2002 | 10:50 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Need help guys. Engine wire harness? (g'sinteg)
What?
Old Apr 19, 2002 | 11:18 AM
salbaje's Avatar
yes they are the same. if you want i have ex harness.
Old Apr 19, 2002 | 12:13 PM
g's integ's Avatar
Default Re: Need help guys. Engine wire harness? (salbaje)
Someone told me that I'll have a problem with my knock sensor at a different thread. is that true? how much are you selling yours cuz so far 150 from other people.
Old Apr 19, 2002 | 12:40 PM
Katman's Avatar
well, the 92-95 Si/EX harness does not have a knock sensor or the IAB (2ndary butterfly) sensor plugs which are integrated on an OBD1 GSR engine harness. If you plan on running a KS then you'll have to wire it up from the ecu to the KS sensor on the back of the block.
but then again, if you're running a reprogrammed P28 ecu, wiring of the knock sensor is useless since the P28 ecu does not look for it, and does not have a KS pcb as well.
[Modified by Katman, 1:41 PM 4/19/2002]
Old Apr 19, 2002 | 12:47 PM
g's integ's Avatar
Default Re: Need help guys. Engine wire harness? (Katman)
i found a p30 ecu as well, does that have a knock sensor?
Old Apr 19, 2002 | 01:08 PM
Katman's Avatar
yes it does in stock form. But if you plan on getting that ecu reprogrammed with the infamous MUGEN program, once that program is installed, it will NOT look for a KS because of that particular program.
Old Apr 19, 2002 | 01:12 PM
g's integ's Avatar
I don't plan to do mugen or chipped the ecu. The only reason i mentioned the mugen p28 cuz it was dohc obd1. Seems that p72 gs-r are over price for me. I was lucky to find this p30 ecu.
Old Apr 19, 2002 | 01:26 PM
Katman's Avatar
cool deal. is your P30 ecu US or the JDM small type?
Old Apr 19, 2002 | 02:21 PM
g's integ's Avatar
I believe p30 ecu's are jdm only.
Old Apr 19, 2002 | 05:05 PM
B18C-EJ1
Guest
Posts: n/a
Nope, they're either US or JDM
jhendry
Dec 12, 2010 08:46 AM
. o 69 o .
Apr 19, 2004 04:26 PM
g's integ
May 3, 2002 08:41 AM
importneeds
Feb 15, 2002 01:47 AM
