Need help finding the right size wheel stud...
Old Sep 28, 2013 | 08:10 PM
Kris05TSX's Avatar
Default Need help finding the right size wheel stud...
I just installed a set of 2013 Accord Sport 18" wheels with Mcguard Splinedrive closed lugs on my 05 TSX. The offset on the wheels is +55. I'm adding a set of 10mm hub and wheel centric custom spacers to put the effective offset at +45. I will be right on the edge of needing longer studs. I want to do this the right way and get wheels studs that are approximately 10mm longer than OEM. I know that Ichiban sells the 40mm studs which is what I need, however, I've heard bad things about the quality of their studs. I would like to stick to either OEM Honda/Acura or ARP studs, however, I'm having trouble finding the application that would work for me. Key thing to remember is that I need an extended stud that is roughly 10mm longer than stock as I will be using closed ended lugnuts. If someone can provide part numbers along with the corresponding lenght of the stud, that would be extremely helpful. Thanks in advance!
Old Sep 29, 2013 | 09:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: Need help finding the right size wheel stud...
That will be hard to find, best bet is to just get good ones, [ARP] and have them cut/machined to what you want. 94
DUKE LADUKE
Suspension & Brakes
19
Feb 16, 2011 11:08 AM
Radim
Feb 4, 2009 07:57 AM
bowflex21
Jan 27, 2007 01:34 AM
Chris93Si
Mar 12, 2005 03:22 PM
