Need help FAST
Old Feb 17, 2005 | 04:53 PM
carraway99's Avatar
Default Need help FAST
I just put my motor in and my exhaust is hitting the shifter. Now thats not a big problem, but the knock sensor is throwing a code. Could this be a result of the exhaust hitting the shifter. My vtec is not kicking on either. Is that the sensor stopping it. Thanks for any advice.
Old Feb 17, 2005 | 05:04 PM
carraway99's Avatar
Default Re: Need help FAST (carraway99)
I tried using another sensor. With the same result
Old Feb 17, 2005 | 05:45 PM
hxtasy's Avatar
why would that be related to the knock sensor? maybe check the wiring harness for the knock sensor, if it got wet or anything when washing the block it oculd have got messed up.
Old Feb 17, 2005 | 06:43 PM
carraway99's Avatar
Default Re: Need help FAST (pennhatch)
will the knock sensor keep the vtec from kicking in?
Old Feb 17, 2005 | 10:29 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carraway99 &raquo;</TD></TR><TR><TD CLASS="quote">will the knock sensor keep the vtec from kicking in? </TD></TR></TABLE>
an ecu when it picks up knock, it will automatically retard the timing, and vtec will not engage.
get a scanner and check to see if its picking up knock, sometimes you can't hear a knock but it is there.
SingleCamin
May 19, 2009 08:23 AM
1.5boosted
Dec 14, 2007 01:45 PM
firstswap
Apr 24, 2006 06:08 PM
codeh22a4
Apr 8, 2004 12:51 AM
