Need help with CTR tb and Skunk2 Intake manifold
Just recently I bought a 92 Hatchback with a B16a1 in it. The car ran fine when I got it, it ran a 9.98 at Irwindale 1/8 strip, full inter, on donuts. I bought a CTR tb and skunk2 Intake manifold I put them on last night and took it for a test drive ran fine in the upper rpm range but the idle sucks sounds like a dirt bike
this morning I tryed reseting the ECU by un hooking the battery then hooked it back up now it smokes like no other and the idle is still crappy, is this normal?? the TB has to sensors on it my old one only had one what do I do which one do I hook it up to? ANY HELP WOULD BE GREATLY APPREACAITED THANKS IN ADVANCE\
Mods:
cf hood
cf spoon mirrors
cf spoon rear wing
16 gunmetal rotas w/ polished lip
ebay straut bars, front upper rear upper lower and c-pillar
white leather GSR seats front and rear
mugen ecu chip
matrix short ram intake
jdm red valve cover
4-1 header
no cat dont know the brand of canister
CTR tb
skunk2 intake manifold
CTR crank pulley
no a/c no ps
AEM cam gears
this morning I tryed reseting the ECU by un hooking the battery then hooked it back up now it smokes like no other and the idle is still crappy, is this normal?? the TB has to sensors on it my old one only had one what do I do which one do I hook it up to? ANY HELP WOULD BE GREATLY APPREACAITED THANKS IN ADVANCE\Mods:
cf hood
cf spoon mirrors
cf spoon rear wing
mugen ecu chip
jdm red valve cover
4-1 header
CTR tb
CTR crank pulley
no a/c no ps
AEM cam gears
on the new CTR throttle body there is a tps and map sensor. the map sensor is the on top of the throttle body. the plug to the map is on the fire wall. take that plug and plug it up to the sensor that is on top of the throttle body. if you need help im personally and i'll do my best to help you out.
nikanoras
Feb 3, 2010 11:44 AM
BillB
Sep 19, 2003 03:16 PM
