Need Help With Compression And Idle Problems
Old Apr 18, 2004 | 02:04 PM
civicshowracing65's Avatar
Default Need Help With Compression And Idle Problems
Today I did a compression test and was wondering if anyone had any suggestions on how I can bring the compression back down. I read normally that the compressons for my 1997 Civic EX are suppose to be around 180 across the board. Here are my numbers
1 - 185
2 - 190
3 - 200
4 - 190
does anyone know how I can bring the compression back down?
Also, another problem I'm having is a really bad idle. This only happens during the day time. My car normally idles at 670rpm. During the day when i stop at a traffic light, my idle goes all the way down to 520rpm and jumps up and down. This only happens during the day and right after I come to a stop at the stop light. What could be the problem for this one?
My steup:
97 Civic EX
greddy 15g turbo it
greddy type 31 ic
msd 8.5 wires
ngk 1 step colder plugs
vafc hack
aem power pulleys
Lucas 440cc injectors
low/high
1000rpm -40%
2000rpm -40%
3000rpm -40%
4000rpm -38%
5000rpm -35%
6000rpm -35%
7000rpm -35%
Old Apr 18, 2004 | 02:30 PM
doublejz's Avatar
Default Re: Need Help With Compression And Idle Problems (civicshowracing65)
your compression numbers aren't really that bad, im guessing your hard on your car. I would be watching #1 its getting kinda far from the 200. Add a cap full of oil in the cylinders and see if your numbers go up, if they do thats usually a sign of rings wearing. If it doesn't really help, I would do a leak down test. The idle jumping around could be: tps, iac, vacuum leak
Old Apr 18, 2004 | 03:35 PM
Default Re: Need Help With Compression And Idle Problems (doublejz)
as for the idle problem this only started a week after i put in the aem alternator pulley. could this have something to do with it?
vtechjunkie
Apr 20, 2010 05:52 AM
tegman85
Mar 22, 2006 04:02 AM
Renegade
Aug 20, 2004 08:16 AM
civicshowracing65
Apr 18, 2004 01:15 PM
kidaniel
Jun 20, 2003 09:21 AM
