need help,car running very hot!!
i have a 92 civic hatchback w/b16a block,piston and rods,blockgard,copper heade gasket,arp head studs,type-r head,t3t4 turbo setup i peice together.the car is running hot!!1st,i tried getting air out of the system,then i bought a stock rad.then i took out the therm.then i flushed the system,then i checked all the grounds,then i installed a water pump,then other problems came,so i swaped the block,still ran hot!!then,i thought it was the head so i bought a type-r head.STILL OVER HEATING!!flushed the system and added water wetter(by redline)STILL OVER HEATING!!then trying to got air out the system,let the car run for 2 hours and kept adding anti.this over heating started since i did the b16 swap(noturbo).when it runs hot,i rev the motor hard and it goes down.this goes on over and over.since i add turbo,it got worst!!!CAN ANYONE HELP ME,PLEASE ITS DRIVING ME CRAZY,,PLEASE I NEED HELP!!!!
Have you ever check if your fan is running? What type of radiator are you using? If you are using a stock civic radiator, It is small. On some cars, when you use the stock radiator when you are hybrid, you will tend to over heat. 1st thing I would do is to flush your radiator. If it sticll overheats, check if your fan is running, try tapping the fan for constant fan on at all times. CHeck your thermostat, it might be out....
basiclly if its not the block guard what you can check is the water pump/hoses for small holes/radiator cap/thermostat or put one in/and flush the radiator and try some water wetter.
efb16
Jan 15, 2005 07:06 AM
CW-ITR-329
Jul 20, 2002 03:50 PM
