need help with brake swap , PLEASE!!!!!!!!
Old Feb 17, 2002 | 12:49 PM
92hybridhhatch's Avatar
From: from Brooklyn NY U.S. Army recruiter in Holyoke, MA, USA
Default need help with brake swap , PLEASE!!!!!!!!
i just dropped a b16a3 into my 92 vx , while i was doin g the swap i fugured i should upgrade the brakes, so i got the complete front knuckles and brakes calipers and rotors off the del sol and directly bolted everything to my hatchback , then i went on to my rear brakes and again directly swapped everything in , after i was done i bled the brakes about 4 or 5 times and still wasnt getting very good pedal feel , and when i finally did i stared the car up and completely lost the brakes , i mean the pedal went dead to the floor , so i changed the masre cylinde and the booster with a direct replacent vx m/c and booster , the same thing happened so i figured the m/c and booster were just to weak for the bigger brakes and 4wheel disk , so i threw in a 92 integra gs m/c and booster and it got a little better but still dont feel as good as they should , does anyone know what the hell this is?and by the way i bled each setup SEVERAL times so there is NO air in the system
Old Feb 17, 2002 | 06:11 PM
tinkerbell's Avatar
Default Re: need help with brake swap , PLEASE!!!!!!!! (colon35)
sorry, this is gonna suck for you, but it sounds like there is air in your brake lines somewhere...
how did you bleed the brakes?
t..
v8killaz
Nov 8, 2010 08:42 AM
1988_96hb
Jul 14, 2009 01:14 PM
UrbanEh
Dec 14, 2005 01:45 PM
jdmcx
Jul 14, 2003 08:12 PM
neumonik
Mar 2, 2002 07:07 PM
