need help badly..tranny going??
okay the weired thing is that one day i drove up state..it was 30 min drive..when i got off the highway, i slowed down put in neutral and when i came to a stop and tried to put it in first i couldnt..tried to muscle it in and there was no way of putting it in first without killing the car and putting it in first. and when its in first, i pop it to second it too would be super hard to put in gear.. and now the really weired thing is that the next day the car would run perfectly and would have that problem and couple of days later it would start to do it again...anybody help me...this thing is killing me..
Hydraulic clutch? Sounds like you need to bleed the air out. Try that first to see if it works. If not then you're looking at a master cylinder (maybe slave) that's going bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Hydraulic clutch? Sounds like you need to bleed the air out. Try that first to see if it works. If not then you're looking at a master cylinder (maybe slave) that's going bad.</TD></TR></TABLE>
might be the master cylinder. cause i bought the slave cylinder new..bleed the lines and still does it..yeah it might be the master cylinder...thanks alot..
-JSpecEk*9-
Aug 13, 2005 02:09 PM
D15Bbigred
Nov 5, 2004 08:24 AM
Rpc07
Oct 7, 2003 03:36 PM
