slave cyclinder????????????HELP!!!!!!!!!!!
I NEED HELP !!!!!!!!!! ok 3 weeks ago my clutch pedal started sticking in and 2day i was bleeding the lines. i did it twice. first time i bleed them and drove it. it would do the same thing jus stay in. the second time it only stayed in once when i was drive it. but still felt weird. can anyone help. i goin to hook up with some chic 2nite and need my ride.
Re: slave cyclinder????????????HELP!!!!!!!!!!! (k20a2ek-9)
First off, learn to speak english. Next did you check for any leaks in the clutch lines or around the slave and master cylinder? If you don't have any leaks one of the two or both could be going out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20a2ek-9 »</TD></TR><TR><TD CLASS="quote"> i goin to hook up with some chic 2nite</TD></TR></TABLE>
We don't care. Borrow a friends car.
Re: slave cyclinder????????????HELP!!!!!!!!!!! (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">First off, learn to speak english. </TD></TR></TABLE>
lol, no leaks anywhere. damn this sucks i jus put on some gsr blades on my ek.
dAng!
If you replaced one and not the other, then you're going to overpower the one not replaced. Either the master or slave cylinder is leaking by internally or externally.
