Need help with b series
Old Jan 8, 2014 | 09:40 AM
weshall0308's Avatar
Default Need help with b series
I'm putting a b18a1 in my 97 civic lx and was wondering if I could use my stock Ac bracket mount and front tranny mount
Old Jan 8, 2014 | 09:42 AM
kyden's Avatar
Default Re: Need help with b series
you can use the rubber, but not the actual mounts on the motor/transmission.
Old Jan 11, 2014 | 04:06 PM
Does it need to come from a 99 00 si?
Old Jan 11, 2014 | 04:15 PM
goldsy's Avatar
It depends. You can use a 99-00 Si one if you're using a B series AC compressor. If you plan on reusing your D series compressor, you'll need the bracket/mount from a 97-01 CR-V or any Del Sol with a B series engine. If you plan on running without AC, you can use any of the above.
As for the front tranny mount, I'm not 100% sure on this but I believe the 99-00 Si or any Integra one will work. I'm not positive on that though. Been quite awhile since I've done a B swap.
Old Jan 11, 2014 | 04:26 PM
SPA Motorsports's Avatar
as far as mounts you can only use the rear mount and trans mount you need to get the T bracket from a civic si and the driverside mount off a civic si and you can use your d series AC comp as long as you get the del sol (vtec) bracket or crv bracket
Old Jan 11, 2014 | 04:28 PM
Ok thanks for the info. Do you know of any cheap websites to get the bracket from besides eBay?
Old Jan 11, 2014 | 04:30 PM
And what year of del sol had the b series
Old Jan 11, 2014 | 04:35 PM
goldsy's Avatar
Just 1994/1995 in North America. There were also D series Del sol's in the same years so if you're looking for one from a Del sol, make sure it's from one with a B16.
goldsy's Avatar
You should easily be able to get a 97-01 CR-V bracket from a junk yard.
Old Jan 11, 2014 | 04:49 PM
Ya I made that mistake of buying a non vtec del sol bracket
lsvtecturbosol
May 12, 2011 07:21 PM
Nicaraguense13
20
Aug 21, 2006 05:01 AM
Moe_Mentum
May 25, 2006 07:11 AM
spike
Jul 12, 2004 09:23 AM
vtecdc2
May 24, 2003 08:55 PM
