need help asap... what the hell happened???
Old Mar 17, 2004 | 05:53 PM
Yosshaa's Avatar
Default need help asap... what the hell happened???
i left my work at 6o-clock today got about 2 blocks away and the car jus died! it turns but, it doesn´t kick over. i wasn´t beating on it, no check engine light came on.. noithing!... 2 cylinders are full of oil (2 closest 2 the distributor cap) anyone know what the hell happened?
engine is a 1.8l non vtec, crower cams, duel springs (2000miles on the head) 100k on the block.
im thinkin
-blown headgasket
-cracked head
-2 fried piston rings
-or worse...
Old Mar 17, 2004 | 06:00 PM
N2O's Avatar
N2O
Default Re: need help asap... what the hell happened??? (ambition)
Sounds like you popped a head gasket. Spark plug do not fire very well in oil.
How Much oil are you talking about?
Old Mar 17, 2004 | 06:04 PM
Yosshaa's Avatar
Default Re: need help asap... what the hell happened??? (N2O)
alot.
Old Mar 17, 2004 | 06:12 PM
N2O's Avatar
N2O
If it is a whole lot you may want to check everything. You can hydro-lock an engine on oil. Pop the head of and go from there.
Good luck
Old Mar 17, 2004 | 06:40 PM
Yosshaa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N2O &raquo;</TD></TR><TR><TD CLASS="quote"> You can hydro-lock an engine on oil. Good luck</TD></TR></TABLE>
that isn't what i wanted to hear.......
Old Mar 17, 2004 | 09:54 PM
N2O's Avatar
N2O
Sorry Bro!
Good luck. Let me know what you find
thakidd
Feb 10, 2008 12:53 AM
97CWITR
Feb 12, 2007 04:14 PM
Greasemonkeyracing007
Aug 6, 2006 11:49 AM
93lsd
Sep 6, 2004 11:11 AM
TypeR0936
May 8, 2003 09:54 AM
