Need Help ASAP Please.
Old May 17, 2003 | 10:32 AM
KEVlN's Avatar
New User
Default Need Help ASAP Please.
A friend and I are putting a Skunk2 coilover kit and ingall's camber kit on his 4thgen accord, and it seems that the drive shaft has pulled out of place from the inside of the cv boot, and we can not get it back in. Any ideas on what to do? We need to get this done ASAP. Thanks in advance.
Old May 17, 2003 | 10:56 AM
Chiovnidca's Avatar
Default Re: Need Help ASAP Please. (KEVlN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KEVlN &raquo;</TD></TR><TR><TD CLASS="quote">A friend and I are putting a Skunk2 coilover kit and ingall's camber kit on his 4thgen accord, and it seems that the drive shaft has pulled out of place from the inside of the cv boot, and we can not get it back in. Any ideas on what to do? We need to get this done ASAP. Thanks in advance.</TD></TR></TABLE>
You'll probably have to pull the band off the boot to line up the bearings. (If your talking about the inner boot.)
Old May 17, 2003 | 11:18 AM
KEVlN's Avatar
New User
Default Re: Need Help ASAP Please. (Chiovnidca)
will the band go right back on? we have a limited supply of tools.
Old May 17, 2003 | 11:24 AM
NonovUrbizniz's Avatar
Loved
not if it's stock... it crimps shut permanently... you have to cut it... but you can use a 4-5" hose clamp for the time being... you can use string or tape if you're DESPERATE. but it's certainly not the best solution. really anything to stop the grease from leaking out and the dirt from getting in will do till you can get a replacement band/strap at an autoparts store.
Old May 17, 2003 | 11:25 AM
KEVlN's Avatar
New User
Default Re: Need Help ASAP Please. (NonovUrbizniz)
Ok, thanks for the help. We will see what we can do.
supracrx
Northern California (Sales)
Sep 26, 2007 02:00 AM
92 civic
Jan 3, 2007 10:35 AM
ilikemyaccord
Aug 29, 2003 01:25 PM
KEVlN
May 18, 2003 02:17 PM
