need help ASAP
Old Aug 29, 2003 | 11:29 AM
ilikemyaccord's Avatar
Default need help ASAP
sup guys...well..i finally recieved my progress camber kit for my 01 accord coupe....we removed the tire...removed the clip...removed the nut to the upper ball joint but how the heck to u removed the upper ball joint...the instructions we got with the kit wasnt very detailed so i was wondering if i can gte any help...i know the ball joint is removed upwards since theres no possible way it can slide downwards..its really stuck in there...thanks
Old Aug 29, 2003 | 12:01 PM
JasterM5's Avatar
Default Re: need help ASAP (ilikemyaccord)
Need to use a ball joint remover. Its like a giant fork. You can pick one up at sears hardware or pepboys.
Old Aug 29, 2003 | 12:28 PM
Aceman64's Avatar
Default Re: need help ASAP (JasterM5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasterM5 &raquo;</TD></TR><TR><TD CLASS="quote">Need to use a ball joint remover. Its like a giant fork. You can pick one up at sears hardware or pepboys.</TD></TR></TABLE>
Those things have caused me more harm than good, ie ripped ball joints if you arent careful. If you use that just be careful.
The best thing to use, but I'm sure you dont have is an airhammer. If you know anyone who has one, use it and it only takes a second and the control arm will break free from the balljoint.
-Ace
Old Aug 29, 2003 | 01:12 PM
Default Re: need help ASAP (Aceman64)
where would i be able to pick up an airhammer?...sears or pepboys ?.....and when do do get it....hit down or up on the ball joint?
Old Aug 29, 2003 | 01:25 PM
Aceman64's Avatar
You would need an aircompressor in order to use an airhammer. If you dont already own, you probably wouldnt want to invest in it just for this. Yes, you can purchase them at Sears.
-Ace
munscher
Oct 27, 2006 06:15 PM
98-0688
Jan 25, 2005 09:53 PM
jschmid
Oct 18, 2004 07:55 AM
ilikemyaccord
Aug 29, 2003 02:48 PM
nick.na
Apr 14, 2003 11:34 AM
