NEED HELP ASAP (dizzy related)
Old Feb 12, 2006 | 08:59 AM
RACEPAK's Avatar
Default NEED HELP ASAP (dizzy related)
hello everybody.
https://honda-tech.com/zerothread?id=1524880
i just came back from the junkyard with two dizzys.
i need to give them back until tommorow morning... so please help.
will one of these work on my b16a2 / b16 vtec ?
thanks it means alot.
the first one has 2 connectors and the second one has only one
the firts one:
the second one:
thanks
Old Feb 12, 2006 | 09:59 AM
IN VTEC's Avatar
Default Re: NEED HELP ASAP (RACEPAK)
Do you have an OBD-1 or OBD-2 engine wiring harness?
Old Feb 12, 2006 | 10:02 AM
RACEPAK's Avatar
Default Re: NEED HELP ASAP (IN VTEC)
b16 vtec obd1
Old Feb 12, 2006 | 10:15 AM
IN VTEC's Avatar
The harness will fit on the two socket distributor, but the legs.....
The legs will not fit on a B-series motor. There should be a leg that points straight up the middle on the distributor cap's flat side.
Old Feb 12, 2006 | 10:19 AM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">The harness will fit on the two socket distributor, but the legs.....
.</TD></TR></TABLE>
yeah... i tryed the first one on the harness and it pas perfect...
The legs will not fit on a B-series motor. There should be a leg that points straight up the middle on the distributor cap's flat side.</TD></TR></TABLE>
ohh thats a bummer.....
can somone please post a picture of the distributer i need? pleaseee
Old Feb 12, 2006 | 11:40 AM
HandCommand's Avatar
Those look like D-series distributors judging from how the "legs" are.
One seems to be OBD1 with 2 plugs and the other OBD2 with 1 plug.
Some OBD2's have only one plug at the distributor also, but it looks different than the OBD2 plug you have displayed.
Old Feb 12, 2006 | 01:23 PM
RACEPAK's Avatar
Default Re: NEED HELP ASAP (HandCommand)
pshh damn i was 100% sure that it was a b serise dizzy...
can somone post a picture of what i need?
Ruthlessef9
Dec 7, 2007 03:32 PM
Ej896
Apr 6, 2007 12:19 PM
RACEPAK
Feb 12, 2006 08:49 AM
Trip
Dec 23, 2004 08:09 AM
HatchBox
15
Aug 15, 2004 07:04 PM
