Need help after seein lots of things...
Old Mar 28, 2003 | 04:46 PM
Vti_man's Avatar
Default Need help after seein lots of things...
Hi
I own a '92 1.6 dohc Vti 160 Hp 4door sedan . and after searchilg a lot over the net , i found several sites talking about hondata , and more things i could use to get more power from my babe... the only thing is that i didnt understood what mods, step by step, i must do to usel hondata in my vti to get the beast out...
Can u explain me? i am not an expert neither in mechanic , or elecrtonics , so dont be too much tecnical and include fotos , if it can be , please.
What costless or cheap mods or hacks can i do to my honda?
Honda rulezzzzzzzz who haves more than 100 hp each liter from a non turbo engine?- Honda and a few more mabe 2 or 3... (Porche , Ferrari...)
Vti
7.5 seconds 0-100 Km/h
220 Km/h topspeed
160Hp from a stock - non turbo engine 1575 cc
I wait from some ideas , pliz...
Old Mar 28, 2003 | 04:52 PM
Shift!'s Avatar
Default Re: Need help after seein lots of things... (Vti_man)
From what I understand, Hondata is a ECU tuning component that will help you tune your ECU to make the most out of your cars modifications. Hondata works best with more highly modified engines so youd probably be better off spending your hard earned cash elsewhere like into your basic bolt ons (intake header exhaust). Once you get past those you may want to consider it then, its your poragative (spelling?).
As for "free" performance stuff you can do - There arent a whole lot you can do. You can take off yoru air filter (not recommended because it has the chance to suck in small dust and debris that could scour your cylinder walls or worse). You can also advance your timing a bit to give you more power. However, if you advance your timing too far you will start getting what is called 'detonation'. Detonation is when your fuel reaches its flash point before the spark can ignite it, causing your engine to fire while the piston is still on its 'up' stroke, which could cause serious engine damage.
Remember, making your car faster is all about risk vs reward.
[Modified by Shift!, 5:56 PM 3/28/2003]
dx_rex
Dec 3, 2010 02:08 PM
jasperjohn
Oct 27, 2008 09:55 AM
quadfourdohc
78
Mar 11, 2007 10:37 AM
Vti_man
Mar 30, 2003 05:13 AM
