my car is frozen? help
Old Dec 20, 2008 | 12:33 PM
turboteg7's Avatar
Default my car is frozen? help
ok so i went to go start my car this morning and its really cold out side and it truns over and almost strarts then it just keeps on truning over ive tryed several times to start it and it wont. what could be the problem. like a frozen fuel line or somthing?
Old Dec 20, 2008 | 12:45 PM
turboteg7's Avatar
dose any one know what i should do?
Old Dec 20, 2008 | 03:50 PM
Lubo_25's Avatar
start with the basics man
battery
starter motor
fuses
main relay voltage
and so on...
Old Dec 21, 2008 | 11:12 AM
fcm's Avatar
fcm
Old Fart
Default Re: my car is frozen? help
If there was any moisture in the fuel lines then yes, fuel lines could be frozen.
When was the last time you replaced the fuel filter?
As mentioned check for spark and fuel, if you are not getting one or the other, [or either one] check fuses.
When you turn on the ign. to run, [not start] can you hear the fuel pump prime the fuel system? 94
spore691
Nov 3, 2012 08:44 AM
weaponsgrade
Jan 8, 2010 09:55 AM
ghostcivic
Jan 16, 2007 02:46 PM
EK k kay
Dec 16, 2004 08:05 PM
drvfast
May 26, 2004 08:29 PM
