Need help?
Old Sep 25, 2003 | 11:43 AM
SadisticRacing's Avatar
Default Need help?
Okay I need your help-everytime I drive my 01-GSR it seems like no matter where I rev to when I shift it doesn't want to go then it does. I've tried shifting high like 6k and won't go right away and then tried 3.5k and still seems to not want to just go. Almost like a bogging feeling. Any help would be great and thank you for your help in advance.
Old Sep 25, 2003 | 11:58 AM
mmuller's Avatar
Mad Scientist
Default Re: Need help? (SadisticRacing)
how's your timming?
Old Sep 25, 2003 | 12:34 PM
Default Re: Need help? (mmuller)
Can it change with by itself because I haven't done anything to the car?
Old Sep 25, 2003 | 08:05 PM
Any other suggestions?
Old Sep 25, 2003 | 09:14 PM
HONDADNA's Avatar
is you check engine light on? it sounds like a misfire - check you plugs, cap, and ignition rotor for wear. your plug gap should be 1.1 mm +/- .01mm.
Old Sep 26, 2003 | 12:08 PM
Default Re: Need help? (HONDADNA)
Check engine light isn't on but I'll check the rest of it and then reply. Thanks
Old Sep 26, 2003 | 07:26 PM
B20T's Avatar
You need to take it to the shop to get a scanner hook up to it ..the scanner will tell you what is wrong at that point of shift.or when you down shift. could be somthing simple to fix. maybe some sensor related problem that the ecu don't see. your car is 0bd2 so a good tech will know what is wrong..
egsickz0
Mar 29, 2009 05:45 PM
leekor12
11
Apr 17, 2007 03:51 PM
