need help with 3 bar sensor
Old Sep 2, 2011 | 01:38 AM
Delsol281's Avatar
Default need help with 3 bar sensor
Alright guy i drive a del sol with ls vtech in it. I just got done slapping a turbo on there. I was wondering where would i put my 3 bar map sensor at and which air line do i use? I know the wire diagram so no need to post the link. When i plug one of the air line to it turn on my car it just cut right off. Would i need a tune? So please pm me if you guys got a solution to my problem and thanks.
Old Sep 2, 2011 | 05:22 AM
cdaiscool's Avatar
Default Re: need help with 3 bar sensor
Tune? Yes, needed.
Where to plug it in? Into a vacuum line. It needs to read both vacuum and boost - thought you read a diagram for it?
I'm glad you put a phone on your car, as well. VTECH is quite an important toy to any child growing up.
So, what's the problem? You don't have anything to tell the car you plugged in a much more powerful 3 bar sensor? Hmm.
Old Sep 2, 2011 | 09:11 PM
lsvtecracer's Avatar
What ecu are you running? You need a tune and will not be able to run a 3 bar map sensor with a stock ecu. You just have to use a vacuum source off the intake manifold.
GotmyTopOFF
Feb 26, 2012 04:06 PM
almostjdmeg
Jan 31, 2010 05:43 PM
1LowSol
Apr 3, 2009 03:10 PM
RTW DC2R
Apr 21, 2006 08:40 AM
BuiltB18C1
Oct 15, 2003 08:39 AM
