Need B16B bearing part#'s and engine specs
Old Dec 23, 2008 | 02:04 PM
ProPower Engines's Avatar
Icon6 Need B16B bearing part#'s and engine specs
Does anyone out there have any info on B16B engine spec's and replacement bearing part numbers, this is a import version of this engine and I can seem to find any info.
I am in need of torque spec's, big end bore size for the rods, Main bearing bore size and replacement bearing part numbers or an interchange to an other engine.
Any and all info will be greatly appreciated.
Thanks in advance for you help with this.
Old Dec 23, 2008 | 02:14 PM
Jas9848's Avatar
Default Re: Need B16B bearing part#'s and engine specs
main bearings are the same as a gsr. rods are the same as any other b16. torque specs are gonna be the same as a gsr.
Old Dec 23, 2008 | 03:43 PM
DonF's Avatar
I think the rod bearings are GSR, type"R". Mains are all the same.
hariastu
Jul 11, 2013 02:19 PM
Civic483973
Jul 10, 2010 08:39 PM
Boost_allways
K Series
Aug 9, 2009 09:03 AM
gus straussen
Apr 9, 2008 11:38 PM
billzcat1
Jan 13, 2005 02:13 PM
