n00b question...
Old Apr 28, 2003 | 11:13 AM
Malgerus's Avatar
Default n00b question...
I thought I was burning some oil, even though I have great compression and no blue smoke. I checked the level this morning, and it was about 3/4 full, even though I topped it up yesterday However, I drive it around for 10 minutes, and hit VTEC a few times, and came home. Let it sit for about 10 minutes, and when I checked it again, it was up to the bottom of the full mark. So which reading do I go by? The dead-cold-in-the-morning reading or after driving and letting it sit for 10 minutes or so?
Old Apr 28, 2003 | 12:57 PM
Hondasaurs's Avatar
Default Re: n00b question... (Mr. S)
I usually check mine after the car has been sitting for a while. I thought mine was a quart low after I did my swap after driving it for a day. I put another quart in it and checked it and it was way to high. Just make sure the car has sat long enough for the oil to drain down out of the head into the oil pan.
Old Apr 28, 2003 | 01:36 PM
RCautoworks's Avatar
Default Re: n00b question... (ZC_CRX)
I would also like to find out which way would be the proper way, people tell me so many different things. As of now I start it up and let it sit for about 5 to 10 minutes then I check it.
Old Apr 28, 2003 | 01:40 PM
joe_bocc's Avatar
Default Re: n00b question... (90blackcrx)
should the owners manual have some info on this.
Anyways, I always chack when the engine is "stone cold". That way, almost all the engine oil has drained into the oil pan and it gives you an acurate way of knowing the oil level.
Old Apr 28, 2003 | 01:51 PM
Malgerus's Avatar
Default Re: n00b question... (joe_bocc)
Yeah, but if I fill it "stone cold" then chances are it'll be too full when I check after I drive the car and let it sit for 10 minutes. I think I'll just keep it 3/4 full.
Old Apr 28, 2003 | 02:01 PM
liquid51's Avatar
within the fill lines is all that's required. Obviously, you'll want to add a little if your riding just above the fill line. But you don't need to take it all the way to the max line.
Old Apr 28, 2003 | 02:05 PM
Malgerus's Avatar
Default Re: n00b question... (liquid51)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liquid51 &raquo;</TD></TR><TR><TD CLASS="quote">within the fill lines is all that's required. Obviously, you'll want to add a little if your riding just above the fill line. But you don't need to take it all the way to the max line.</TD></TR></TABLE>
True. I just want enough pressure for my MaD tHiRd GeAr VtAk though!!!
Old Apr 28, 2003 | 03:12 PM
raene's Avatar
I would assume that the extra oil in the crankcase would help keep the oil pump pickup happy, however? So it IS necessary for, say, an autoX day?
Old Apr 28, 2003 | 03:23 PM
sporkcrx's Avatar
Default Re: n00b question... (raene)
You check the oil when it's warm.
VTEC_PRODUCTION
Nov 5, 2007 10:31 AM
Exeed
Aug 24, 2006 12:37 PM
Ding
Honda Civic (2006 - 2015)
Jul 19, 2006 03:47 AM
2k1 SSM GSR
Sep 16, 2004 06:01 PM
Chris
Jun 22, 2001 10:08 AM
