i've heard that a turbocharged v-tec doesnt work well together...is this true? any feedback from turbocharged vtec owners? turbocharged non-vtec owners?
well you got fed some very very very bad information. My car ran its *** off before i took it off the road agian, i know plenty of cars that run great. Everyone else chime in.
Vtec and Turbo love each other
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zomart »</TD></TR><TR><TD CLASS="quote">whoever told you that doesn't know what they're talking about.</TD></TR></TABLE>
Amen. VTEC and boost work wonders together if done properly.
I've heard of H22's not making impressive gains from JRSC's and turbo's after VTEC kicks in.....
It is true to a point, but it will not prevent you from makin big power. The idea is that the high-overlap of VTEC cams lets boost bleed out while both valves are open.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad_asz_mushak »</TD></TR><TR><TD CLASS="quote">i've heard that a turbocharged v-tec doesnt work well together...is this true? any feedback from turbocharged vtec owners? turbocharged non-vtec owners?</TD></TR></TABLE>
i think that its a tuning issue. Turbos can have a fine line between being a well thought out setup and a quickly pieced together one. If your setup isnt tuned well it isnt going to operate well. Sizing a turbo correctly works wonders...
true, it depends on the setup, timing isnt a big deal but can hurt a turbo setup with no ignition controll
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
This is the only aspect I have herd discussion of. While you can adjust cam gears to dial that out, you also have to consider overlap on/off vtec lobes.
