My motor is hungry, why?
Old Oct 24, 2004 | 08:32 AM
fucT's Avatar
Default My motor is hungry, why?
Ok, so recently, well, just recently I have noticed a loss of oil. About 2000 miles into an oil change I'll be missing 2-3 quarts. I may get on my car 2-3 times a week, and they're short sprints. It's an OBD I B18C. I was on the dyno last week and I didn't see any bluish smoke. I'm not dripping at all. Where is it going?
Old Oct 24, 2004 | 11:56 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
how many miles are on the engine?
Old Oct 24, 2004 | 12:15 PM
Kamin's Avatar
Default Re: My motor is hungry, why? (fucT)
there are really only 3 places the oil can go
combustion chamber
cooling system
ground
losing that much oil, you should see a noticable problem in one of those areas.
Old Oct 24, 2004 | 02:21 PM
fucT's Avatar
Default Re: My motor is hungry, why? (Kamin)
Ok so, a few days ago, Friday, I check my oil in the morning before being driven and there was no oil on the dipstick. I added 2 quarts. I just went to check my oil and it's showing WAY over. Like as if there was adequate amount of oil and then added 2 quarts. I'm confused.
Old Oct 24, 2004 | 02:49 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fucT &raquo;</TD></TR><TR><TD CLASS="quote">Ok so, a few days ago, Friday, I check my oil in the morning before being driven and there was no oil on the dipstick. I added 2 quarts. I just went to check my oil and it's showing WAY over. Like as if there was adequate amount of oil and then added 2 quarts. I'm confused.</TD></TR></TABLE>
where do you check your oil?
needs to be on a FLAT surface, engine not running. if you check it immediatley after you drive you may get a low reading because there is still oil throughout the system that hasnt drained back.
drain your oil immediatley do NOT DRIVE 2 quarts overfilled.
Old Oct 24, 2004 | 03:01 PM
fucT's Avatar
I checked it in my drive way. It's as flat as it's going to be. The car hadn't even been driven for the day. I'm draining it directly after school tomorrow. I just want to know if there is something causing it to look low without it really being low.
Old Oct 24, 2004 | 05:34 PM
DeadVet's Avatar
Look at both sides of the dipstick, i have found that some cars will read a little higher on one side than the other.
Old Oct 25, 2004 | 02:15 AM
Supahr_Ed's Avatar
i notice when there is NO oil at all on the dipstick, you need about only 1 quart and maybe a little to reach the top mark...remember, there is still oil in the motor.
As kamin said, only those 3 places is where oil goes..check you plugs, see if there fouled out, maybe the burnin of the oil isnt that noticable in the exhaust. 2 quarts of oil/wk and driven only 2-3 /wk is pretty bad, it shouldnt be hard to find the oil..
Old Oct 25, 2004 | 05:03 AM
fucT's Avatar
Default Re: (Supah_Eg6)
Thanks for the help fellas. I'm going to change the oil around 1pm and keep an eye out from there.
Old Oct 25, 2004 | 08:35 AM
rev-speed's Avatar
when u check oil on a dipstick use the low side reading (the high side is from the dipstick going in at an angle
the two dots (hole)on the dip stick stand 4 1 qt.
if oil reaches the bottom dot add 1 qt and ur full.
210jdmgsr
Aug 15, 2007 03:55 PM
fackyou
Oct 4, 2006 03:45 PM
motormike40
Sep 18, 2006 07:23 PM
XxRoCkMaNxNEOxX
Nov 28, 2004 09:17 AM
2SlowAccord
Jul 2, 2003 03:24 PM
