my lsvtec quest
Old Mar 19, 2008 | 09:18 AM
215HPLSVTEC's Avatar
Default my lsvtec quest
hey whats up...... well i had an ls non vtec for awhile and now it died, so now im getting ready to do my lsvtec motor. this friday march 21 2008 is my birthday. im heading to jhpusa.com to pick up my parts. im not sure what pistons i should use. i ordered over sized itr pitons but now i was changing my mind to b16 p30's. im not sure now. well the rest of my parts are rc 310cc injectors, blox intake manifold, 70mm throttle body, super tech valve springs and retainers, super tech high compression valves, stock gsr cams for now, h beam rods the head is ported and polish already, blox fuel pressure reg. itr oil pump, itr water pump, hondata i/m gasket, arp head studs, and thats about it. i want to kow what would be a good piston and cam to use????????? thanks for time
ooo and what kinda bearings should i
use??? im planing to take it too
9000rpm's........ thanks once again
Old Mar 19, 2008 | 09:41 AM
civicstar's Avatar
Default Re: my lsvtec quest (215HPLSVTEC)
well its all about opinions but the jdm b16 will put out more compression then the ITRs and if u get a high lift piston u need alil more compression to push them, for cams, depends how you are gonna drive it, daily or race. i would get some skunk2 stage twos or something similar in size with jdm b16 pistons, get some acl bearings or even oem
Na-Spirit
29
Sep 8, 2010 11:40 AM
bakomack
May 4, 2010 07:48 PM
TypeRbuild718
May 7, 2007 12:44 AM
team-savage
26
Oct 25, 2006 08:32 AM
