my low compression culprit
Old Aug 24, 2010 | 01:05 PM
Peeonu25's Avatar
Default my low compression culprit
piston out of my h22a
best part, cylinder walls = spotless...
if i had my camera charger id show you better pics, its broken right off almost like it was jus t a bad cast. you would think a 10.5:1 compression piston would be able to handle a little more compression.
Old Aug 24, 2010 | 03:29 PM
Peeonu25's Avatar
Default Re: my low compression culprit
just pulled the other 3 pistons... ALL of them have cracked or broken ringlands... still no scores in the cylinder walls and all of the rings are still in awesome shape.
Old Aug 25, 2010 | 11:23 AM
xtremescouts's Avatar
boosted or no? ive seen that a couple times on boosted b series with stock pistons. what were you runnin for psi?
atleast the cylinder walls are good. All you gotta do is get a new set of pistons and rings and maybe a light hone. would be a good time for forged though.
Old Aug 25, 2010 | 06:26 PM
Canuck99's Avatar
Most broken lands I have seen is from a lean mixture causing detonation, and you don't always hear it either. Excess Cylinder wall clearance can do it to. Just some thoughts.
90efhatch
Sep 8, 2010 07:47 AM
kpjo4
Jan 8, 2010 07:38 PM
Lamchop0000
28
Jul 7, 2006 06:50 PM
done
Apr 29, 2002 06:04 AM
Halo
Nov 6, 2001 07:34 AM
