Compression on B18b1
Old Dec 29, 2009 | 06:45 PM
kpjo4's Avatar
Default Compression on B18b1
So I heard a healthy ls engine has cylinder bore compressions about at 180psi, my ls engine is currently pushing out 120psi in all 4 cylinders... Is it time for a rebuild or is it fine since the cylinders all have the same amount of pressure?
Old Dec 30, 2009 | 12:34 AM
kpjo4's Avatar
Default Re: Compression on B18b1
did a wet compression test and got the cylinders to 150 psi ><, so i'm thinking it may be the piston rings
Old Dec 30, 2009 | 06:03 AM
TekBuDDy's Avatar
ya if the compression went up then its your rings, prolly normal wear and tear?
Old Dec 30, 2009 | 07:03 AM
bakedkarma's Avatar
make sure the engine is warm when doing your tests.
Old Dec 30, 2009 | 08:48 AM
sde780's Avatar
different testers read differently
Old Dec 30, 2009 | 02:16 PM
kpjo4's Avatar
it could be wear and tear, so i may buy a new pair of pistons and rings. Would the cylinder walls be fine?
Old Jan 7, 2010 | 10:52 PM
kpjo4's Avatar
well the wet compression test made a jump from 120 to 150psi, so there are problems with the pistons and or rings; it may as well need to be rehoned. Well seeing as that I was just wondering why would all the cylinder banks be showing such a low pressure, is it likely for all cylinder banks to be like this? Becasue I thought low compressions usually only happen to one or two cylinder banks?
Old Jan 7, 2010 | 10:53 PM
Spec R's Avatar
did u pull all 4 plugs out?
i remember wanting to kick my engine to the curb when a known-good snap-on compression tester read 95psi.
i then pulled all four plugs and voila 180psi across.
Old Jan 7, 2010 | 11:34 PM
kpjo4's Avatar
as in all 4 ignition coils? yes and the spark plugs, so I had 3 venting cylinder banks while 1 was attached to the gauge. got a reading of 120 on all 4 banks.. =[
Old Jan 8, 2010 | 01:18 AM
TheAsian's Avatar
You will need to hone the cyl walls so the new ring will seat properly.
Old Jan 8, 2010 | 10:48 AM
Spec R's Avatar
yeah u did it right, one plugged in and 3 venting...sorry for the bad news.
Old Jan 8, 2010 | 07:38 PM
kpjo4's Avatar
yeah... =[
time fore a rebuild!
02BladeRider
Jul 7, 2017 05:49 AM
DulinDragons
Dec 3, 2009 09:05 PM
98civicEX
Apr 8, 2003 10:55 AM
Brian_92GSR
Aug 1, 2002 08:38 PM
Halo
May 5, 2002 07:03 PM
