IS MY CLUTCH GOING?????
Old Jun 22, 2009 | 09:40 AM
jdmkha's Avatar
Default IS MY CLUTCH GOING?????
I have a weird smell when I am on a hill. you know when your on a hill and you have to balance the clutch with the gas/ well there seems to be a stinky smell. I checked my t/f but its good. any suggestions.??
Old Jun 22, 2009 | 11:45 AM
fcm's Avatar
fcm
Old Fart
Default Re: IS MY CLUTCH GOING?????
Clutch is slipping. 94
Old Jun 23, 2009 | 06:00 PM
standbackimapro's Avatar
Only on a hill? if its only on a hill id say your not driving right on the hill
Old Jun 24, 2009 | 10:06 AM
AdmiralCrunch's Avatar
if you're trying to balance the clutch and the gas when you're going up a hill then you need to re-learn how to drive a standard. if you do this often enough then it will surely wear out your clutch in no time.
you should only use the clutch when you're going from a dead stop, of if you are shifting gears. if you need more power on a hill then you must downshift
Old Jun 24, 2009 | 04:20 PM
KWayRacing's Avatar
Just come to a complete stop then use the clutch when the light goes green whatever. Sitting there slipping the clutch on purpose will ruin a clutch and fast.
Old Jun 24, 2009 | 04:37 PM
jdmkha's Avatar
No No No,when I am at a dead stop on a hill,you would have to balance the clutch out with gas in order not to roll back. ya digg. but I think already got my answer from FCM thanks FCM for that answer.
Old Jun 25, 2009 | 05:22 AM
fcm's Avatar
fcm
Old Fart
No No No, you do not "balance the clutch" to keep from rolling back on a hill, you use the brake for that, [hand brake if you have to] to go from a dead stop on a hill in a standard is a bit of a trick and will take some learning, slipping the clutch on purpose is not the way, as mentioned it will quickly destroy the clutch. 94
Old Jun 25, 2009 | 09:46 AM
B16Civic93's Avatar
yeah you need to be a little more clear, are you sitting at the light the whole time slipping the clutch or are you talking about after sitting there with your foot on the brake you go to take off and the amount you are slipping the clutch is causing it to burn? if so what rpms are you leaving the light at while you are 'balancing' the clutch and the gas?
altoid04
15
Nov 18, 2009 04:10 PM
Cypher0117
23
May 16, 2005 07:15 PM
dyases
Nov 30, 2003 09:25 PM
2fast4u
Apr 25, 2002 08:36 AM
slash00R
Jan 3, 2002 01:37 PM
