my check engine light is stuck on
Old Feb 5, 2016 | 06:14 PM
jeffman's Avatar
Default my check engine light is stuck on
So I bought a 99 civic with an si swap, full b16a2 with LSD. Well my check engine light was blinking, simple enough. I read the code and it was my 02 sensor. I replaced both o2 sensors and now the check engine light is stuck on, no longer blinking just solid. I have tried unhooking the battery and holding the brake and let it sit for 15 minutes. I even tried to take out the fuse under the hood that is supposed to reset it. And yes I hooked it up to an OBD2 and there are absolutely no codes, not even any solid state codes. when i turn the car on the check engine light just stays on.. If anyone could help me out with this I would appreciate it.
Old Feb 6, 2016 | 03:03 AM
v4lu3s's Avatar
RTFM
Default Re: my check engine light is stuck on
On all the time or on when jumped? What issues does it have when running?
Old Feb 6, 2016 | 05:31 AM
jeffman's Avatar
just on all the time
Old Feb 6, 2016 | 06:21 AM
motoxxxman's Avatar
do you know if the correct ecu was installed with the swap?
when you first turn on the ignition (without cranking), does the cel come on for a few seconds, then blink of for an instant, then come back on? or does it just come on and stay on? (if it does not blink off for a moment, it could be a bad main relay)
Old Feb 6, 2016 | 06:22 AM
jeffman's Avatar
Oh and yeah my car runs perfect, absolutely no problems... just the stuck solid check engine light.
Old Feb 6, 2016 | 06:23 AM
jeffman's Avatar
When I turn ignition on with car off just stays solid.
Old Feb 6, 2016 | 10:24 AM
jeffman's Avatar
OK SI I figured it out. Jumper pin was left in when I bought the car. So anyone else who has this problem if the check engine light is solid and stuck on and the there are no codes.. check the jumper plug near the ECU. I guess the prior person jumped plug to see what was wrong and just left it in.
Old Feb 6, 2016 | 11:49 AM
motoxxxman's Avatar
lol, nice. easy fix ftw!
Danny Sihapanya
Dec 15, 2012 06:45 PM
03djmAccrd
15
Sep 25, 2010 04:33 PM
keegur
Acura TSX
Jan 10, 2009 01:33 PM
lowered94accord
Mar 16, 2007 08:27 AM
redludevtec
Aug 15, 2004 04:00 PM
