my car is running pretty bad
Old Nov 19, 2002 | 05:32 PM
Rob Dizzle's Avatar
Default my car is running pretty bad
just got the car back last night
timing is set to full advance. if any lower it runs really bad. But right now, there is very little power and the car does not respond to throttle very well
engine just rebuilt last week with
jdm itr pistons
itr cams/springs/lmas
honda bearings
hondata s200
aem cam gears
rc 310cc
skunk2 intake manifold w/hondata gasket
i did not check before the engine went in, that the timing belt was installed correctly. once it gets light out, i am going to check it over
what is the process of going about and checking to make sure everything is 0* TDC
since I am in break in, I only have revved to 4k. accelerating is very slow. there is not much torque at all
when cruising above 3k rpm, there is a lot of slight jerking. the engine is not running smoothly at all.
here are the things I need to check tomorrow
-timing belt is on right
-cam gears are aligned correctly
-timing should be at 14*
-spark plug gap?
anyhelp would be greatly appreciated
Old Nov 19, 2002 | 05:43 PM
boostinb18's Avatar
Default Re: my car is running pretty bad (Bob-DC2)
have you had the hondata tuned yet??? cause im oretty sure it just comes with a base program then it needs to be tuned! and that will make it run like ***... sounds like that set up wioll rip when it runs right
Bryant_novtec
Jan 13, 2014 01:09 PM
JDMlyfestyle
23
May 19, 2008 05:52 PM
CRVTEC0WNZJ00
Nov 1, 2005 08:53 PM
intekragsr
Mar 21, 2003 10:23 AM
Rob Dizzle
Nov 20, 2002 02:35 PM
