install of oil catch can
Old Nov 14, 2002 | 07:08 PM
EVOCELICA's Avatar
New User
Default install of oil catch can
does installing a catch can eliminate the PCV valve?
Old Nov 14, 2002 | 07:29 PM
sleeprhatch's Avatar
Default Re: install of oil catch can (EVOCELICA)
no
Old Nov 14, 2002 | 08:04 PM
EVOCELICA's Avatar
New User
Default Re: install of oil catch can (sleeprhatch)
so the pcv valve is incorporated in to the plumbing of the catch can
Old Nov 14, 2002 | 08:07 PM
Desslok's Avatar
It basically goes between the PCV and IM, just comes w/ longer hose. I'll take some pics of mine tomorrow. (Greddy)
Old Nov 14, 2002 | 08:29 PM
EVOCELICA's Avatar
New User
Default Re: install of oil catch can (sp)
right on, thanks also did you fill your catch can with a steelwool baffle
Old Nov 15, 2002 | 06:54 AM
Desslok's Avatar
I used steel wool, however some people use scotch brite or brillo pads. I have heard that BBs are the best to use, because the moist, oily air condenses better on them and less goes into the IM, but I thought that would be too heavy, so I did the steel wool, plus I already had the steel wool. Just make sure none can break off and get sucked in, use screen if you have to.
Old Nov 15, 2002 | 11:47 AM
EVOCELICA's Avatar
New User
how much steel wool did you use, should I fill the catch can to the top or just put a small amount in
Old Nov 15, 2002 | 12:05 PM
Desslok's Avatar
I basically copied these guys:
http://www.c-speedracing.com/howto/c.../catchcan.html
Check this out too:
[URL][http://jdmfan.com/technical/performa...tch-tank//URL]
Old Nov 15, 2002 | 01:24 PM
EVOCELICA's Avatar
New User
thanks
Old Nov 15, 2002 | 04:02 PM
Jeff C's Avatar
I am using a Moroso...its baffled and works fine.
Old Nov 16, 2002 | 10:02 PM
EVOCELICA's Avatar
New User
where did you get the extra hose for the catch can, I can't seem to find the clear tubing anywhere?
Old Nov 17, 2002 | 08:30 AM
Jeff C's Avatar
This is what I am using from The Home Depot. Its 3/8"IDx5/8ODx1' Braided Vinyl Tubing w/ SKU #705065.
[Modified by Jeff C, 12:35 PM 11/17/2002]
Old Nov 17, 2002 | 03:21 PM
EVOCELICA's Avatar
New User
Default Re: install of oil catch can (Jeff C)
thanks
Old Nov 17, 2002 | 04:58 PM
Tweakmeister's Avatar
the clear tubing might collapse.
you may need fuel line. (just think rubber tubing...can be bought anywhere).
Old Nov 17, 2002 | 06:51 PM
EVOCELICA's Avatar
New User
Default Re: install of oil catch can (Tweakmeister)
I don't think greddy would sell the catch can with some tubing that would collapse.
true rubber tubing can be bought anywhere "but" the places I've looked (kragen, and autozone)
Old Nov 17, 2002 | 08:09 PM
I don't have the greddy kit so I don't know what they offer, but the generic clear vinyl tubing you buy from Home Depot is not made to hold up at super high temps with oil flowing through it.
fuel line tubing should be available at any auto parts store (like autozone).
Old Nov 18, 2002 | 08:08 AM
Jeff C's Avatar
The Home Depot description of the stuff I suggested:
"-Braided PVC has four times the working pressure of single wall PVC.
-Smooth, dense bore maximizes flow and reduces sidiment buildup
-Excellent resistance to acids, alkalis, and mony solvents."
Also, the stuff is $.56 per foot, that doesnt sound generic to me.
I have used it for 5k miles now w/o a problem.
Old Nov 18, 2002 | 08:24 AM
Desslok's Avatar
If you have a solid flow of super high temp oil, then you have some major problems. On a normal car, blow by gases are what passes throught this, it contains HC and some oil. With the motor running, pull off the PCV valve and put your hand over it, don't worry, it won't burn you.
Old Nov 18, 2002 | 01:06 PM
thank you for the info, I am aware of this already.
I'm glad the clear vinyl tubing is working for you, but if you run your car very hard (such as tracking) then you will have hot oil "vapor" in the tubing for a prolonged amount of time. Several instances this has caused the tubing to collapse.
at ~$.50/ft give it a go. I'm sure it will be fine for most people.
Old Nov 19, 2002 | 04:41 PM
EVOCELICA's Avatar
New User
thanks fellas i went and picked some up it looks good and works fine.
Old Nov 19, 2002 | 06:18 PM
Farnsrocket's Avatar
I bought that clear **** from Home Depot.......yay, it's pretty and clear!!!!............and freakin almost closed up on me.
Fuel line from Napa works well.
mithious
19
Apr 21, 2015 03:23 PM
keenspeed94
May 2, 2007 01:00 PM
DIYaccord
Welding / Fabrication
34
Dec 5, 2004 08:15 PM
Farnsrocket
Mar 4, 2002 10:41 AM
