Is my block surface good enough for a headgasket??? Need to be decked?
Old Jul 6, 2003 | 03:47 PM
sporkcrx's Avatar
Default Is my block surface good enough for a headgasket??? Need to be decked?
Well I've been scraping away at this ****** for forever. Think it's good enough for a head gasket now? The other thing I'm worried about is the nicks from the razor blade, but the paper gasket should fill that in right?
Old Jul 6, 2003 | 04:32 PM
EKhatch's Avatar
Default Re: Is my block surface good enough for a headgasket??? Need to be decked? (sporkcrx)
IMO, you need to get those cylinder walls taken care of, and while it is at the machine shop they can finish cleaning up the deck for you!
Old Jul 6, 2003 | 07:22 PM
sporkcrx's Avatar
Default Re: Is my block surface good enough for a headgasket??? Need to be decked? (EKhatch)
The cylinder walls are just like that from the **** I was spraying on the surface. They're much better cleaned, trust me. Any opinions on the surface.
Old Jul 6, 2003 | 08:53 PM
eg6h8k's Avatar
hmm looks like to many scratches to me..u need to clean em up more..i think the head gasket will seat...but just to be on the safe side..no scrape mark..use a 3" blade and go over it..
Old Jul 6, 2003 | 08:54 PM
civicsitek GanGsTa's Avatar
Id clean it up more
Old Jul 6, 2003 | 08:56 PM
bluedelsol's Avatar
get some steel wool (scratch pads) (not real heavy, i took an S.O.S. pad and ran it under water for a wile and got all the cleaner out) and put some oil on pads and scrub it for about 5-10 mintes and it will look good as new.
Old Jul 6, 2003 | 09:27 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">The cylinder walls are just like that from the **** I was spraying on the surface. They're much better cleaned, trust me. </TD></TR></TABLE>
The fine steel wool is a good idea along with a light oil as a lubricant.
Old Jul 6, 2003 | 09:44 PM
Usdm1's Avatar
wow freddy crooger
use a new razor blade youll get better results
Old Jul 6, 2003 | 10:16 PM
altoid's Avatar
Default Re: Is my block surface good enough for a headgasket??? Need to be decked? (Usdm1)
take out teh dowel pins, and when you get it all cleaned off, using something such as a scotch brite pad, take a fine file and pressing firm and steady, go from one corner to the opposite corner then from the other corner to the other opposite corner (i.e. left rear to right front, then right rear to left front). That way you can see if you're deck is warped and it allows for a rough surface so the head gasket can seal...head gaskets don't like smooth surfaces...ohh and do the same to your head
Old Jul 6, 2003 | 10:20 PM
EKhatch's Avatar
Default Re: Is my block surface good enough for a headgasket??? Need to be decked? (altoid)
Good advice altoid. A meathod often used to clean up old thermostat housings to ensure a good seal.
Old Jul 6, 2003 | 10:36 PM
sporkcrx's Avatar
Yea that sounds like a good idea. On an old v8 we used a big piece of wood with sand paper on it, so maybe I'll try that too. I might also use the file method. I swear to god I'm never touching an engine with a paper headgasket again!
Old Jul 6, 2003 | 10:40 PM
aeolus's Avatar
i say have a machine shop deck it just to be sure.Why take a chance?
Old Jul 7, 2003 | 12:30 PM
AzG35's Avatar
Default Re: Is my block surface good enough for a headgasket??? Need to be decked? (aeolus)
Deck it, its cheap insurance. Any strange debris or knicks can cause a leak. Better do it now, then after you have already put it back together.
Old Jul 7, 2003 | 02:24 PM
RCautoworks's Avatar
Default Re: Is my block surface good enough for a headgasket??? Need to be decked? (AzSi22)
If you clean it up a little more I think you should be fine, but I would get it decked just for the reinsurance. Like the other guy said, would you really want to go threw all that trouble after its installed ?
Old Jul 7, 2003 | 07:20 PM
SuperMan19's Avatar
New User
Default Re: Is my block surface good enough for a headgasket??? Need to be decked? (90blackcrx)
how much would decking the head cost?? umm looking for average prices..??
Old Jul 7, 2003 | 08:14 PM
sporkcrx's Avatar
Default Re: Is my block surface good enough for a headgasket??? Need to be decked? (SuperMan19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperMan19 &raquo;</TD></TR><TR><TD CLASS="quote">how much would decking the head cost?? umm looking for average prices..??</TD></TR></TABLE>
Ditto. I only called one place a week ago and they wanted $60 just to hot tank!!! To put a head in a machine, close the door, and turn a ****! Screw that ****.
Old Jul 8, 2003 | 08:11 AM
AzG35's Avatar
Probably 40-50 to deck/resurface. You don't really need to hot tank, but its a good idea to. I just used lots of degreaser (castrol super clean), and a decent pressure sprayer. Works pretty well.
Old Jul 9, 2003 | 04:47 PM
drumking15's Avatar
if you go to the parts store they sell gasket remover ive found that this works rather well...but man you gouged that up pretty bad...id get it decked a few thousands to enusre a clean surface
Old Jul 9, 2003 | 06:12 PM
Atomic 1320's Avatar
Default Re: (drumking15)
The gasket will fill in some nicks and scratches. That wont be a problem as long as there not verry close to the cylinder. The main problem should be if its warped or not? The only way fo find that is with a machined stright edge and feeler gauges. i would rather spend the few extra bucks now. than maybe having to pull that beast back out and having it done later. That would really suck! good luck
Old Jul 9, 2003 | 07:26 PM
sporkcrx's Avatar
Default Re: (Atomic 1320)
Yea, it's not that bad actually. I already assembled the block, and I'm going to test for any warpage before I put the head on. But I think it will seal, we'll see
MrCivic242
Mar 5, 2014 02:04 PM
D16SiHatch
25
Oct 14, 2007 02:14 AM
gnar kill
Sep 2, 2005 02:53 PM
TeamCracka
Feb 16, 2004 06:34 PM
3rdGteg
Oct 5, 2003 09:27 PM
