msd and wire problem on crx
Old Sep 2, 2006 | 12:24 PM
killabeezturbo's Avatar
Default msd and wire problem on crx
?1:i put in my msd due to that my car will just turn over and wont start and also after i wile it finaly will what could be the prob
and ? 2:is i converted my car into obd1 from obd0 and when i wanted to check code. my car does not have the blue clip under the glove compartment is it that it can be some were else or is there any other way to check the check eng code
shmigolz?
Old Sep 2, 2006 | 04:17 PM
lightcrx's Avatar
ur jumper harness should have extra wires to jump andd it'll show you the code. cant figure it out pm me
-joseph
Old Sep 2, 2006 | 06:24 PM
Default Re: (lightcrx)
yhea well what du u meen the one that is atached that runs to noc,o2,vtec wires is that the one
because i have the boomslang pig tail i beleve
Old Sep 2, 2006 | 11:03 PM
lightcrx's Avatar
do you still have the boomsleg instructions?
-joseph
Old Sep 2, 2006 | 11:46 PM
no well i think i look i was tring to get ahold of u earlyer im u but im on trail
Old Sep 3, 2006 | 10:57 AM
Default Re: msd and wire problem on crx (killabeezturbo)
any one no y after i installed my msd my car turns over but no ignition the afrer a while it will start i tripple check al my shyt and now wire play and i also tryed a new coil blaster and it still did the same .
any one can help?
Old Sep 3, 2006 | 12:53 PM
i found put how to check my code very diff but it worked
my concern is the msd prob now ?
anyone
well i have a b16 and it is theowing egr code but is weired because im running p28 any one might now the problem
oh i also reset the ecu and nothing mann
Old Sep 3, 2006 | 01:10 PM
lightcrx's Avatar
your p28 must be a auto.. take the msd out and see if it starts, it if does you probley hooked it up wrong or its no good
-joseph
Ryan.
Apr 29, 2008 11:48 AM
91h22cb7lx
Jul 14, 2007 02:08 PM
vteckilla7
Aug 8, 2004 01:41 PM
hybridnorth
Jul 10, 2003 11:53 PM
uneekcrx
Apr 11, 2002 09:05 PM
