MSD issues - HELP!!!
Old May 8, 2011 | 08:26 PM
99SlammedCivic's Avatar
Snipper Snapper
Default MSD issues - HELP!!!
Hey guys,
The R has an external msd ss blaster that is run to the dizzy inside the cap.
I decided to remove it and replace it with a new dizzy just because.
When I installed the new dizzy, the car doesn't even attempt to start. I tried another dizzy off another R of mine and that did the same thing.
I then re-installed the original dizzy w/ the external blaster and the car started right up.
With the new dizzy, the car doesn't even attempt to start at all.
It does have an alarm on the car but I"m not sure if that has anything to do with it.
Also, I did not see the MSD box anywhere in the car.
Suggestions?
** ALSO THE CAR IS THROWING A CODE FOR TDC **
Pictures:
Old May 9, 2011 | 11:16 PM
WickedSol's Avatar
Default Re: MSD issues - HELP!!!
Make sure your new dizzy is setup with the internal oem coil.
Old May 10, 2011 | 04:03 PM
fcm's Avatar
fcm
Old Fart
Ditto that^^^ it's a good bet the OEM coil was removed when the MSD blaster coil was installed.
I removed my stock coil when I installed my MSD blaster coil and the MSG distributor cap. 94
1sikhatch
Apr 26, 2010 02:35 PM
byc_cb7
Aug 28, 2009 10:15 AM
turbotime
Sep 27, 2006 07:22 AM
Doug684
18
Jan 11, 2004 03:28 PM
