mounting rods to pistons
Old Jun 30, 2002 | 07:47 PM
LSR 97's Avatar
Default mounting rods to pistons
If you look at a rod from any B-series motor (in this case a type-r) there are notches on both sides of the rod, which are necessary to hold the rod bearing.
My question is when i have the wrist pins pressed into the rods is there a certain way that the rods need to face? intake or exhaust, according to the notches? or since they look identical from both sides can they simply be pressed into the piston any way?
Thanks in advance.
LSR
Old Jul 1, 2002 | 09:16 AM
sgT's Avatar
sgT
Default Re: mounting rods to pistons (LSR 97)
notches to the exh side
Steeve_Civic
May 28, 2012 10:37 AM
4cylfiend
Mar 11, 2011 10:33 AM
kpjo4
Mar 11, 2010 07:56 PM
K2e2vin
Jun 12, 2006 01:10 PM
boost fed ls
Jan 29, 2005 04:20 AM
