motor problem
Old Apr 11, 2004 | 09:56 AM
cstay's Avatar
Default motor problem
i was driving to school last week (2 hours) and about a mile from school my car died motor was hesitating and not running right. i think i sucked in some water along the drive. got to school did a compression test got bad numbers i think 60 and 40 in the first two cylinders. i riped off the head and i couldn't find anything wrong. the head is flat, valves are fine, rods are fine, head gasket is fine, we measured the head bolts to se if i stretched them and 3 of them were 3 thousands shorter than the rest. thinking maby i stretched the rest. but all of the head bolts were tight. my oil is now a nice milk color. Any suggestions on what happened?
Old Apr 11, 2004 | 11:26 AM
Stripped Honda's Avatar
99-0104
Default Re: motor problem (cstay)
you probally just blew a head gasket slap on another one use new head bolts and try it out ... i would also have your head resurfaced
Old Apr 11, 2004 | 11:38 AM
Kendall's Avatar
If the headgasket is fine, then it leads me to believe that there is a problem with the piston rings and that a rebuild is necessary.
Old Apr 11, 2004 | 12:46 PM
0bd1_Kanobe's Avatar
Was it smoking before you took the head off.And what color was the smoke,Also was it knocking?
Old Apr 11, 2004 | 12:47 PM
cstay's Avatar
Default Re: (BseriesHybrid)
it smoked white when it misfired
Old Apr 11, 2004 | 05:57 PM
spoonek9's Avatar
white smoke + milky oil = blown HG
Antifeeze does horrible things to your rod and crank bearings. Might want to do a fresh rebuild. Good luck
Old Apr 11, 2004 | 06:49 PM
proformance's Avatar
you may have cracked the head. if the head gasket was still good and everything else looked fine, i dont see how i can be anything else. the piston rings have nothing to do with the mixing of the fluids. go and get the head pressure tested at a machine shop to see if there are any unseen cracks. if nothing is found, just resurface the head and slap on a new head gasket/head bolts.
Old Apr 11, 2004 | 07:11 PM
spoonek9's Avatar
Default Re: motor problem (proformance)
cracked head could be possible. Either way, antifreeze eats away at you bearings.
Old Apr 11, 2004 | 07:52 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstay &raquo;</TD></TR><TR><TD CLASS="quote"> my oil is now a nice milk color. </TD></TR></TABLE>
headgasket (it can still be bad but look OK)
cracked head
cracked block
coolant is mixing with oil those are the only 3 possibilites.
Old Apr 11, 2004 | 08:27 PM
chictunner97ex's Avatar
Default Re: motor problem (Kamin)
I agree 100% with Kamin...your HG can look fine but definatly be bad. How many miles are on your car? Was your HG ever replaced before? Good piece of advice that I was always told is always start working on the smaller possible solution (replace HG, headstuds, and resurface head) and if that does not take care of the problem move on to the next bigger possible solution to your problem. good luck
Atomic_EF9
Mar 29, 2011 11:51 AM
primerpimpin
Oct 23, 2009 06:49 PM
soysauce90CRXsi
Nov 19, 2008 05:15 PM
DS_Vtec
Nov 18, 2007 08:08 PM
bdicustoms
Aug 25, 2004 07:35 PM
