motor mounts
Old Oct 17, 2003 | 04:42 AM
dip-set's Avatar
Default motor mounts
what are signs of a bad motor mount...? 96 ls
Old Oct 17, 2003 | 04:50 AM
rsbad454's Avatar
Default Re: motor mounts (teg-your-it)
time to get Hasport...............
Old Oct 17, 2003 | 04:52 AM
dip-set's Avatar
Default Re: motor mounts (rsbad454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">time to get Hasport...............</TD></TR></TABLE>
thats not mentioning anything about a sign of a bad motor mount...
Old Oct 17, 2003 | 04:54 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it &raquo;</TD></TR><TR><TD CLASS="quote">what are signs of a bad motor mount...? 96 ls</TD></TR></TABLE>The engine moves too much. Excessive vibration and/or clunking noises when you get on & off the gas. Sometimes it makes the shift linkage goofy if the engine moves far enough.
The mounts aren't rocket science. You can see most of them, usually. Look for the rubber parts rotting or cracked apart. Grab the valve cover & try to rock the engine back & forth.
Old Oct 17, 2003 | 04:58 AM
dip-set's Avatar
Default Re: motor mounts (JimBlake)
ok im not getting any of those signs except i think the engine moves to much...i think im just gonna beat the **** out the car till i really brake something..."if it aint one thing its another" and im quite tired of that ****...
Old Oct 17, 2003 | 05:38 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
which mount do u think is bad? i have some mounts for sale.
Old Oct 17, 2003 | 05:50 AM
dip-set's Avatar
Default Re: motor mounts (SIXTYdashONE)
i have no idea which one..the rear possibly..i just feel like the motor moves to much..
Old Oct 17, 2003 | 07:11 AM
89JDMcrx's Avatar
i had that problem with my car. After I bought energy suspension motor mount inserts the problem went away. My a/c mount was busted and the mount inserts fixed it.
bl1tzk1213g
May 16, 2007 10:31 AM
ivicr
Oct 30, 2005 01:10 AM
HondaNerd
Jun 20, 2005 07:40 PM
StrictlyJdm94
Apr 27, 2005 06:16 AM
Justin95GSR
Mar 4, 2004 11:25 AM
