Motor Build Up?
Old Feb 14, 2004 | 05:29 AM
b16crx1's Avatar
Default Motor Build Up?
is there a step by step guide to build up a b18c1?
Old Feb 14, 2004 | 07:38 AM
Kataku2K3's Avatar
Default Re: Motor Build Up? (b16crx1)
This is a start as Andy just built his FI motor... His is a C5 but it'll be the EXACT same for a C/1... https://honda-tech.com/zerothread?id=765604 Good Luck
Old Feb 14, 2004 | 09:12 AM
b16crx1's Avatar
Default Re: Motor Build Up? (Kataku2K3)
thanks alot for the link... that will help me out alot.... question: should i get a helms manual for a integra to help me build the motor too???? also what is a good sleeve to get??
Old Feb 14, 2004 | 09:22 AM
Kataku2K3's Avatar
Yea, definately get a manual... It'll tell you everything you need to know... What kinda motor are you building? Most of the motors we build at the shop for customers and friend's run Golden Eagle sleeves... They'll hold up just fine (even on Duc's 712whp street EJ6 at 30lbs.) but Scott (CrazyCompression) don't particularly like them... I'd first go with AEBS then RS... I've never seen/built a Benson sleeved block but I've heard good stuff... If you click on the link in my sig for Scott's NA setup you can see how nice RS sleeving looks... It's really all in the machining, AEBS and RS just do really nice work were as sometimes GE's don't look perfect... Just my $0.02
Ric4k
13
Mar 20, 2010 10:35 AM
Civicman86
May 18, 2007 09:06 AM
Topdawgg
Dec 22, 2005 09:05 AM
TurboBoostedEG
Aug 17, 2005 10:09 AM
E Swift
Jul 10, 2001 11:44 AM
