I need help
Old Feb 12, 2004 | 05:38 PM
sillvercivicgsr's Avatar
Default I need help
I was driving down the road last Saturday night and my car bogged out the cut off. After getting the car home the next day I started looking for what the problem was and this is what I found.
I've had a couple of people tell me that there's a chance my head could be blown. What are the chances that this is the case?
Old Feb 12, 2004 | 06:20 PM
RedlinedVTEC's Avatar
Default Re: I need help (sillvercivicgsr)
I can't really tell what I'm supposed to see that little white looking speck? Better pics are a must, as well as a better description of the symptoms you are experiencing. I'm gathering that your car cut out and now won't start? Was this after normal driving, an over-rev? Details. Then what have you checked? Are you getting good compression numbers, spark to all cylinder, fuel?
Old Feb 13, 2004 | 07:02 PM
Default Re: I need help (RedlinedVTEC)
Not the white spec. Look to the right of it and the break in the cam. The intake cam is broken in half. It was after normal driving. I'm wanting to know what the chances are that the whole head is blown. It was a Crower stage 2 cam. Any help would be greatly appreciated.
Old Feb 13, 2004 | 07:12 PM
Sorry, couldn't tell from the pic the cam was broken. Well your head is going to be a mess, bottom end will need at the very least a rebuild given you didn't crack a sleeve or scar one up what boring .5 over. Pull the head and evaluate the damage. Sucks, I've heard/seen so many broken crower stories, but I ran a set of 63402s for over two years without any issues. Here's a link to one:
http://honda.hybrids.jp/forum/...part=
Best of luck
Old Feb 13, 2004 | 07:27 PM
evilhatch2.0's Avatar
have you called crower, maybe their cam went defective???, either way raise hell, and get free cams and maybe some other free stuff., that is very unusual, I say manufacturers defect!!!!!!!!
Old Feb 14, 2004 | 09:51 AM
Default Re: I need help (evilhatch2.0)
Likely they won't give you anything more than a free set of cams if anything at all. like you're really excited to run another set after the last ones broke and cost you an engine.
HondaH22a#1
Aug 10, 2011 07:08 PM
eg6madness
Oct 30, 2007 11:05 AM
whitelightning
Jan 30, 2003 04:30 PM
r2x
40
Oct 2, 2002 06:28 AM
