motor bogs under any throttle
Old Dec 1, 2004 | 12:32 PM
  #26
zensoku207's Avatar
bump bump
Old Dec 1, 2004 | 02:49 PM
  #27
zensoku207's Avatar
up up up
Old Dec 2, 2004 | 04:35 AM
  #28
zensoku207's Avatar
i think it may be out of gas......:whoops:
Old Dec 2, 2004 | 05:46 AM
  #29
turboxsi's Avatar
Default Re: (zensoku207)
damn you will feel stupid if thats the case. Doesn't your car have a fuel gauge??
Old Dec 2, 2004 | 06:07 AM
  #30
nvmyb20hatch's Avatar
Default Re: (turboxsi)
we had a problem similar to that in a customer car at my work, we realized that with any throttle voltage, the fuel pump would stop working and fuel pressure would completely fall off. it ended up being that the ecu fuse was blown,and the customers vafc was actually powering the ecu enough for the car to idle, but not enough to run. hope this helps cause this car was a bitch and a half to figure out what was wrong.
Shaun
Old Dec 2, 2004 | 06:47 AM
  #31
zensoku207's Avatar
yeah, if i had a vafc i would check that out...but all the fuses are okey dokey....
but i had like 1/5 of a tank, and now its done to just above E....and i jus replaced the fuel filter too....so gotta check that **** for leaks, then try it again...
but yes, i will indeed feel stupid....glad it runs, but braindead nonetheless...
Old Dec 2, 2004 | 07:14 AM
  #32
good luck with everything
Old Dec 2, 2004 | 07:23 AM
  #33
fast94ex's Avatar
Mine was doing this last week, i checked every possible thing i could and it turned out my distributor went out. Changed the dizzy and it worked fine, if you have checked the entire fuel system and electrical like i did then it has to be the dizzy.
Old Dec 2, 2004 | 09:16 AM
  #34
b20z2's Avatar
Default Re: motor bogs under any throttle (zensoku207)
could be the ignitor in the distributor going bad.
Old Dec 2, 2004 | 12:38 PM
  #35
zensoku207's Avatar
ignitor, coils replaced in the dizzy....plugs ok, wires ok...i mean the engine idles fine...its just when it gets gas, any at all...
i still have to try switching out the tps and mas plugs just for ***** n giggles, but i doubt thats what the problem is.
man, for something so easy, i mean it sounds like a definite fuel problem, but its being a pain in the anus.
Old Dec 3, 2004 | 05:13 PM
  #36
Nightrder_88's Avatar
Default Re: Problem off idle
You need to look into your catuletic converter, sounds to me like its plugged up.
Old Dec 3, 2004 | 05:31 PM
  #37
zensoku207's Avatar
well, i would if there were one...
Old Mar 21, 2005 | 10:49 PM
  #38
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zensoku207 &raquo;</TD></TR><TR><TD CLASS="quote">i got an ls/vtec, the timing is fine, new cap, rotor, plugs, wires, idles perfect....thanks.</TD></TR></TABLE>
leave this country now. scammers
WARNING DO NOT BUY FROM HIM
paradigm_shift
May 31, 2009 12:11 PM
ShawnbobHatch
Dec 30, 2008 12:00 PM
freakasis
Feb 24, 2007 01:27 PM
confewcious
Jul 30, 2005 09:02 PM
2k1_ITR_0736
Sep 26, 2003 10:33 PM
