More effective- Rotors or pads?
Old Jun 19, 2002 | 03:46 PM
performula's Avatar
Default More effective- Rotors or pads?
Old Jun 19, 2002 | 03:56 PM
Kamin's Avatar
Default Re: More effective- Rotors or pads? (performula)
go play with the search
i asked a while ago in the comp. forum and they all said get some brembo blanks, good pads and good fluid and it will stop your car hella fast. thats what i did (its all sitting on the floor right now, gonna install this weekend)
Old Jun 19, 2002 | 04:01 PM
smokin rubber's Avatar
Default Re: More effective- Rotors or pads? (KAMiN)
And pads are generally cheaper than some bling rotors.
Old Jun 19, 2002 | 04:14 PM
travis's Avatar
Default Re: More effective- Rotors or pads? (smokin rubber)
Sometimes true. I pay $80/pair for Brembro blanks, and $100-130/pair for front pads. The BLING rotors can get pretty damn expensive for no good reason.
Actually, only tires will make your car stop fast. The benefit to pads, fluid, and rotors is that their design will help you delay brake fade from heat soak.
If I had to decide between rotors or pads, assuming your rotors are within a safe thickness, I'd swap out the pads (and fluid).
[Modified by ITR#231, 6:15 PM 6/19/2002]
Old Jun 19, 2002 | 05:11 PM
kyler's Avatar
I'm pretty impressed with this setup:
-Brembo blanks about $50 a pair at Nopi
-AEM (Nissin) Pads about $40 whereever
-Goodridge G stop stainless brake line (make HUGE difference, rock hard pedal) $110
-I use dot3/4 synthetic by Mobil I believe (silver bottle, black label, 500degree boiling point)
-and of course some good tires as thats whats touching the ground
i switched from powerslots and axxis Metalmaster pads and I like this setup alot more
hth.
Old Jun 19, 2002 | 05:16 PM
Kamin's Avatar
Default Re: More effective- Rotors or pads? (kyler)
im using axxis ultimate pads. (well they go on friday)
http://www.collettimotorsports.com - rotors and fluid (ate superblue) - 25~$ per rotor
http://www.stoptech.com - pads (65$)
and yes, only tires stop you (technically) but pads and rotors are a good base.
[Modified by KAMiN, 6:17 PM 6/19/2002]
Old Jun 19, 2002 | 05:30 PM
Kamin's Avatar
then you want a nice setup
good pads (axxis ultimate) good fluid (ATE superblue or motul 600 racing)
i spend uder 200$ for pads, rotors, and fluid.
EverTheWise
Suspension & Brakes
May 18, 2018 10:50 AM
JmurGSR98
15
Jul 23, 2012 09:03 AM
wyee99
Honda Civic (2001 - 2005)
May 13, 2009 03:11 PM
mr tl
Dec 5, 2001 07:30 PM
WuShu
Aug 18, 2001 09:55 AM
