modifying oil pump
Old Jul 29, 2004 | 02:37 PM
TrackWeapon's Avatar
Default modifying oil pump
Hi, I got an H23 vtec and I want to go with a dry sump system.
the engine is totally in pieces, I don't have any bolts holding anything!
even the oil pump is for now in pieces.
ok the question is, would it be a good idea to remove a part from that pump since it's not going to be needed.
i'm talking about keeping the inside gear (because it looks like its a support for the crankshaft??) and remove the outside one
would that be a good idea or can I remove the both of them or neither of them and keep that oil pump?? (remember the engine is in pieces so no mechanical mods would be hard to do)
Old Jul 29, 2004 | 06:26 PM
Default Re: modifying oil pump (TrackWeapon)
anyone?
Old Jul 30, 2004 | 05:59 AM
ttt
Old Jul 30, 2004 | 05:13 PM
earl's Avatar
You can pull out those gears with no problem. In fact, if you were to leave them in, they would probably burn up as they would be spinning without oil.
BTW, you should also remove your balance shafts and plug the appropriate passages.
Old Jul 30, 2004 | 05:54 PM
DXDOHCVTEC's Avatar
Default Re: modifying oil pump (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">You can pull out those gears with no problem. In fact, if you were to leave them in, they would probably burn up as they would be spinning without oil.
BTW, you should also remove your balance shafts and plug the appropriate passages.</TD></TR></TABLE>
make sure you have proper pcv.
Old Jul 30, 2004 | 09:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">BTW, you should also remove your balance shafts and plug the appropriate passages.</TD></TR></TABLE>
alreasy done, I even removed the water pump impeller (just keeping the water pump gear) and going with electric water pump, with those thing removed from the crankshaft, should help a lot in the engine acceleration
well not if the oil pump is replaced by an external one, but still...
LobeSex
Oct 6, 2009 01:24 AM
NoVALude
May 12, 2005 03:06 PM
crazyslowhatch
Oct 17, 2004 10:04 PM
Mefain
May 16, 2003 09:02 AM
