mitutoyo
Old Sep 8, 2005 | 11:00 PM
White_EK49's Avatar
Default mitutoyo
okay, i will sum it up pretty quick. this is for engine build. mic the main, rod journal on the crank. do i need .001 resolution or .0001 also the difference on graduation. Starrett has .0001 and Fowler has .0001 pretty confusing on resolution and graduation. I am no where near a machinist, on their website they have the 101, 102 and 103 series. I don't have the funds to go digital. I want something that will work. some of the mic have rachet, and or locks. some is just plain. all engine builders please help... don't tell me to search. because i did. i just refuse to use plastigauge.
Modified by slow29 at 12:28 AM 9/9/2005
Old Sep 8, 2005 | 11:23 PM
mmuller's Avatar
Mad Scientist
Default Re: mitutoyo (slow29)
.0001
Old Sep 9, 2005 | 12:00 AM
White_EK49's Avatar
Default Re: mitutoyo (mmuller)
okay so it is .0001 and not .001 this graduation will work for measuring the rod and main journals then. anymore info. thanks.
Old Sep 9, 2005 | 12:01 AM
sporkcrx's Avatar
I have the fowlers but I never even care about the 4th digit. Most engine specs only go to 100 thous anyways.
ps- I am no pro engine builder, just do it occasionally in my garage.
Old Sep 9, 2005 | 12:15 AM
White_EK49's Avatar
Default Re: mitutoyo (sporkcrx)
that is what i wanted to hear. most places don't carry .001 like the fowler. I only saw them in .0001 and Mitutoyo of America says they are on back order from JDM land for 1 month or so. So the .0001 works then and just ignore the last digit.
Old Sep 9, 2005 | 12:40 AM
sporkcrx's Avatar
Well the fowlers I have go to .0001, but I never measure that deep into it (hell, I dont even know how to read the last digit on the mic).
Old Sep 9, 2005 | 12:48 AM
White_EK49's Avatar
your funny...thanks for the help. i will go get the .0001 then. better to go big then small.
Old Sep 9, 2005 | 02:07 AM
sporkcrx's Avatar
Actually I think I do remember how to read the .0001 digit. I think it's whatever number of the left horizontal lines, lines up best with the horizontal lines on the right. Hard to explain by words For what it's worth, my fowler set was about $100 off the snap-on truck, and it's 4 mics, 0"-4", ratcheting, with locks.
Old Sep 9, 2005 | 05:30 AM
1fastVX's Avatar
FYI...Fowlers are cheap units. It you want accurrate .0001 measurements from mics that you will have forever stick with mitutoyo or Starrett. Have you tryed the link below for the Mitutoyo mic?
http://www.use-enco.com
John
Old Sep 9, 2005 | 05:33 AM
1fastVX's Avatar
Default Re: mitutoyo (1fastVX)
Here is the 3 and 4 inch mics at use-enco. It shows that it is in stock.
http://www.use-enco.com/CGI/IN...LMK32
John
Old Sep 9, 2005 | 05:51 AM
1fastVX's Avatar
Here is a nice Brown & Sharpe 0-4 inch set which should measure all the parts you need for an engine rebuild. These are also high wuality mics which are much better than the Fowler units.
John
Old Sep 9, 2005 | 09:25 PM
Kevedge's Avatar
if i were you id definately invest in going digital, it makes things so much easier. we use alot of mitutoyo products at work, all digital, .0001. But honestly, we never even care too much about the fourth digit. Most of the time its all 100 thousandths like mentioned above.
Old Sep 10, 2005 | 12:49 PM
FIGARILA's Avatar
Default Re: mitutoyo (Kevedge)
j and l industrial has the Starret mics on sale and get the .0001 graduation. ratchet ends just help you from getting misreadings from over tightening
Old Sep 10, 2005 | 02:40 PM
snowseeker's Avatar
Default Re: mitutoyo (Heron of Alexandria)
I have an electric mitsu .0001 0 - 6. I always have to clean the thing to get a accurate measurement past 2.5 - 3.0 Should have got a dial.
SoSlo
Dec 1, 2007 11:03 AM
tegman2
Sep 26, 2005 01:58 PM
jmouchett
May 14, 2005 10:37 AM
prdtr15
Sep 27, 2003 02:27 AM
DarkSol97
Jul 22, 2002 10:43 PM
