Missing when cold , Smell Fuel Through Exhaust
I got a 89 civic si with a b20b obd1 converted , car has chipped ecu ( ran fine at first) , walbro 255 pump, stock inject. The car runs bad when its first started up, It misses, hesitates. Even after it warms up it still acts like it misses a little. it does throw a cel once in a while but I cant check it because after i turn the car off it doesnt come back on....any ideas? Car has a new magnaflow high flow cat on it...I smell fuel when I start the car , its 100%% Running rich. It has a 4 wire 02 , ( I dont know the condition of it. I have had it for a while ) would unplugging the 02 sensor be a way to test it?? Im lost ....
You meen as in the tune? I just dont understand why it ran fine for the first month? I would have thought if it was the tune it would of ran like crap from day one...?
Most likely your timing is off / you don't have to run the car like its a race car for it to get off timing / over the years your timing belt needs to be replaced because it stretches and can jump a tooth or your tenshioner can get loose after a while and just needs to be tightened have a timing check on your car
not sure how to check it on my obd1 converted ef? The plug is NOT under the dash by the glovebox. The car is a 89 Si
I have the same kind of problem with my obd1 b20b4 eg but my hesitation is only under 3k rpm. A shop told me it's the LS base map I'm running on my chipped p28 and that i need a tune.
What program is it? o2 won't do anything. Motors also change conditions causing the need for a new tune. This is assuming everything on the motor is good
Temp, it's a junk ls base map.
Wikedeye
Feb 7, 2012 03:40 AM
kamui
May 16, 2006 04:14 PM
