Missfiring at full throttle
Old Jun 17, 2002 | 05:31 PM
95civicSI's Avatar
Default Missfiring at full throttle
I have a 1995 honda civic ex I did a b-16 p30 swap. My car missfires at full throttle but if I back off, it runs good without missfiring.It seems to only missfire at normal tempature if I full throttle it before normal temp it won't missfire.I tried everything no one can understand why it only missfires at normal temp and not at all times. E-mail if you think you know what the problem is at (civic95_SI@yahoo.com) .
Old Jun 17, 2002 | 07:11 PM
C-speed's Avatar
Default Re: Missfiring at full throttle (95civicSI)
Most likely it is fuel related.. you are running lean at WOT.. The reason it doesn't when the engine is cold is because the ECU adds extra fuel when the engine isn't up to operating temps.
Old Jun 17, 2002 | 08:08 PM
Unsung's Avatar
did you try bringing your timing back a bit?
Old Jun 18, 2002 | 05:09 PM
95civicSI's Avatar
Default Re: Missfiring at full throttle (G3-TEG)
How can I fix it I think it sounds like it's not getting enough fuel I tried
Old Jun 18, 2002 | 05:10 PM
C-speed's Avatar
Raise the fuel pressure.. whats it at now?
miniwhl
Aug 23, 2010 02:07 PM
crxb16a90
Engine Management and Tuning
Jan 2, 2010 12:58 PM
adamsjm5
Nov 20, 2006 04:22 PM
turboteg2nv
Nov 28, 2005 10:29 PM
bikeboy80
Oct 4, 2002 06:41 AM
