Minimum wiring to run.
Old Mar 12, 2016 | 08:56 AM
GT500FTW's Avatar
Default Minimum wiring to run.
Hey guys.
One of my mates is building a stock car using a B16 OBD2 engine.
He has cut out all of the unnecessary wiring to save as much weight as possible.
The problem is he's not getting spark.
He has wired in the distributor and vtec.
Are there any other sensors that he must connect in order to get spark?
Old Mar 12, 2016 | 01:25 PM
2point1's Avatar
Default Re: Minimum wiring to run.
Is he getting power to the distributor?
Does the Ecu have power?
Does the Ecu have ground?
What Ecu is being used?
Old Mar 12, 2016 | 02:26 PM
motoxxxman's Avatar
uhhhhh, every sensor on the motor needs to be wired, and then some. I hope you're not saying the only things currently connected are the distributor and vtec...
Old Mar 14, 2016 | 03:42 AM
carlowerks's Avatar
"He has cut out all of the unnecessary wiring to save as much weight as possible"
he saved 1kg worth of wires.. 50 kg = 0.1 seconds off the quarter mile
the main relay must have power when cranking it powers the ecu and injectors
Harrymonk
15
Dec 16, 2018 10:44 PM
fenix4o9
Jul 7, 2007 11:35 PM
doberneckerj
Feb 13, 2006 05:19 PM
serious
Jan 6, 2003 06:12 AM
