minime help
Old Apr 27, 2005 | 03:56 PM
90crxmike's Avatar
Default minime help
i have a problem i didnt have a map sensor before so my motor would shut off wouldnt hold an idle and that was it and know i got the map sensor i dosent shut off but the idle bounces and the temp goes up right before the max then i shut it off wut could it be
Old Apr 27, 2005 | 07:22 PM
Kendall's Avatar
First off, give the entire cooling system a good inspection. Once you get the temperature stabilized, then check for vacuum leaks.
Old Apr 27, 2005 | 10:18 PM
CRXDrew's Avatar
**** man... sounds like a bad install. Make sure you got coolant in her... and maybe perform a compression test....
Be more clear when you post. Organize your thoughts and display them legibly. You get way more answers that way.
For a second I wasn't gonna post after reading... but its late and I'm procrastinating on a paper... and I was in your shoes before... minus the car problems
buster97
Apr 15, 2013 11:56 AM
adam00integra
Jan 2, 2012 10:03 PM
heyitzspikey
Jan 29, 2007 09:19 PM
JMvtec
20
Nov 14, 2006 06:47 AM
talley2191
Jan 31, 2006 07:13 PM
