milled head w/ ctr cams
Old Aug 19, 2004 | 09:17 AM
hybridEj6's Avatar
Default milled head w/ ctr cams
Im going to mill my head .030. I have a stock jdm gsr block. I also have a ctr intake cam. Will i have clearance issues? Im thinking not because the ctr cams have such little lift.
Old Aug 19, 2004 | 10:01 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: milled head w/ ctr cams (ekhybrd)
you will be fine as long as you do not go past +2 on intake cam
Old Aug 19, 2004 | 12:24 PM
vtecb20coupe's Avatar
B A N N E D
only one way to know for sure. go buy some playdo and have fun...
Old Aug 19, 2004 | 01:13 PM
DYNO-PRO
Default Re: milled head w/ ctr cams (vtecb20coupe)
actually playdough is not good to use because it expands after it is compressed by the valves...there is a specific type of clay that needs to be used
Old Aug 19, 2004 | 03:13 PM
TIRENECK's Avatar
Default Re: milled head w/ ctr cams (HOOKUPS)
whats this clay u guys talking about and what does it do?
Old Aug 19, 2004 | 04:33 PM
Fleas_Ef's Avatar
Default Re: milled head w/ ctr cams (TIRENECK)
dont no the actual name of the clay but would like to no so BUMP
Old Aug 20, 2004 | 09:25 AM
DYNO-PRO
Default Re: milled head w/ ctr cams (Fleas_EF)
u need to use modeling clay, you can get it from your local hobby shop
Old Aug 20, 2004 | 11:20 AM
_BEN_'s Avatar
Default Re:
Remember too when you mill the head or put a different thickness head gasket it retards(thicker) or advances(thinner or milled) your cam(s).
Someone posted how much timing is changed per a .010 a while back but I cant find it.
Old Aug 20, 2004 | 01:29 PM
hybridEj6's Avatar
Default Re: Re: (_BEN_)
So i heard someone say if you advance it 2 degrees you can possibly get piston to valve slap? So if it retards the timing 2 degrees and i advance it two degrees to get it back to 0,0 will i risk damage to my head or pistons? I plan on bring it to the dyno to get re tuned once the head and everything is slapped back together
EGtypeR408
Oct 15, 2010 04:57 PM
ek444ls
Nov 22, 2009 11:10 PM
joe.wong321
Mar 25, 2008 09:58 AM
ACrite3404
Feb 10, 2006 02:19 PM
PotatoePAPA
Jun 3, 2003 05:26 PM
