milled head question
if you mill it .030" your timing will be off by -2 degrees, so set your cam gears to +2 to true them. So, by advancing the intake cam gear you will be advancing the dizzy too....so i guess if you want your ignition timing to be at OE specs then you would need to advance it a little bit....b/c if your cams are retarded 2 degrees then your dizzy is too b/c its attached to the intake cam.
i hv a q uestion too. i hv a h22a, so the dizzy is on the exhaust cam..i mill my head like 35 thou..and my cam gear is set to 0 now..i use timming gun to check my timming and it's 17 degree on idle...is it correct or i need to move my cam gear..cuz the car seems slow. i hv stage 2 cam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frozenb »</TD></TR><TR><TD CLASS="quote">i hv a q uestion too. i hv a h22a, so the dizzy is on the exhaust cam..i mill my head like 35 thou..and my cam gear is set to 0 now..i use timming gun to check my timming and it's 17 degree on idle...is it correct or i need to move my cam gear..cuz the car seems slow. i hv stage 2 cam </TD></TR></TABLE>
Advance your cams 2 degrees, then play with the dizzy. 17 is correct though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Advance your cams 2 degrees, then play with the dizzy. </TD></TR></TABLE>
u mean i advance my intake or exhaust cam???
i beleive u talking about exhaust cam, rite??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Advance your cams 2 degrees, then play with the dizzy. 17 is correct though.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frozenb »</TD></TR><TR><TD CLASS="quote">u mean i advance my intake or exhaust cam??? </TD></TR></TABLE>
CamS as in two of them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racekar »</TD></TR><TR><TD CLASS="quote">how about if i have stock cam gears.. can i just advance my dizzy?</TD></TR></TABLE>
Your cam timing still won't be correct and odds are it'll have more of an effect on power than will two degrees of ignition timing.
JDMs1eeper
18
Aug 24, 2003 12:01 AM
